Hello guys, here are 3 renders created for a job i am working on. I have used Path Tracing, 16000 samples, 1920:1024 and each image took about 6 hours to render with 1 gtx 780 gpu. Please give me your feedback.
Cheers
Interior Design
Just a little bit of photoshop. The trees are washed up and i tried to fix that up in photoshop but messed it up. The landscape is a plane which i have placed outside of the room, but when i corrected the white balance on the octane camera, the landscape image turned blue and overexposed. Anyway i re-rendered with just the hdri (no backplate) and it looks better. I have also added some bloom and glare for the ceiling lights.
I am now rendering the room again, because the furniture scale was too big. I had to measure it using a cube and re-adjust it.
i7 4770k, GTX780, 16gb ddr
Thanks. In my last message i wanted to say "now rendering" instead of "not rendering". Anyway, here is the rescaled furniture (correct scale). This time i have used PMC with max rejects 1000, 16000 samples, max depth 100 and it rendered for 15 hours (i was out of town, so i just let it render.) I thought that the quality would be better if i use PMC with max rejects 1000 instead of PT, but the quality seems to be the same...maybe PT a little better.
ps: the armchairs are sculpted in cinema4D. Didn't like anything from evermotion and their models are low poly (for my tastes)
Furniture looks much better to scale. In my personal opinion, I wouldn't use PMC unless you've got a lot of glass and caustic calculations that need to happen. PMC is much better suited for that. Otherwise, you're just using an engine that will take longer to converge.
Win10x64 / AMD Ryzen 9 5900X / 64g RAM / 2 x RTX 3090
