OctaneRender® for Poser (Windows) 1.55 [TEST] - OBSOLETE
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Poser 1.5 TEST RELEASE.
Poser Version
This version runs on Poser9/PoserPro2012 and Poser10/PoserPro2014, on Windows XP, Vista, 7 and 8.
Nvidia Driver Version
This release requires Nvidia drivers 335.23 or later.
- Operating System (ie. Win XP, Vista, 7, 8)
- 64 bit (Msg me if you need 32 bit)
- Amount of RAM
- Nvidia driver version
- Poser version (Poser -> Help -> About Poser) - list the build number (eg. 9.0.3.23027)
- OctaneRender for Plugin version (ie. X.XXa)
- Also have ready a copy of the octaneplugin.log and cuda.log file from your Poser temp direction (Poser -> Edit -> General Preferences -> Misc tab to find the temp directory)
- config.xml, which is in C:\Users\[username]\AppData\Roaming\Poser Pro\9 for Poser 9/2012 and C:\Users\[username]\AppData\Roaming\Poser Pro\10 for Poser10/2014.
Still TODO
- Implement subd processing for props (only implemented for figures at the moment) - will require a Poser SR patch
- Specular map image power defaults to 1 at the moment for skin materials with specular maps. Probably should be about 0.2.
- Export materials to OCM format
- Fix when camera zOrbit is non-zero, AND using large xOrbit and yOrbit values puts the Octane camera out of rotation synchronisation
If you have questions....
- Read the latest up-to-date on-line manual
- Read the PDF manual (pdf manual is installed into C:\Program Files\Smith Micro\[poser version]\Documentation)
- Read the FAQ
- Watch the Features Video
- Read the Features Blog Posting
- Watch the Introductory Tutorial
- Watch the Instancing Video
- Check the Facebook Page
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Download the plugin from the following links:
- OctaneRender for Poser 1.55.0.33 (64 bit)
- OctaneRender for Poser 1.55.0.33 (32 bit)
samhal
Got it! Thanks!
i7 6800K (6 core), 24 GB, GTX 1080 8gb, Titan X 12gb
ch0pper
thanks!
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
mlru
cool, thanks!
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
Erick
1st time user of the 1.5x version of the plug-in, so bear with me, please =)
Could it be, that the copy and paste of materials doesn't work all the time? Or perhaps it's an user error...
When I copy a material (right-click "Copy <node name> Node ), e.g. the hip material of a V4 figure, which I then want to paste to the torso material of the same figure, the option "paste material ... " (by right-clicking the mat.zone, so the context menu opens) is greyed out, so I cannot choose it. Whereas the option "paste <node type> to all materials named xxxx" is available.
Also, a "mainWacros" window keeps popping up for me, with something that looks like a counter/or an information in it. Saying: "Unknown" with a value behind it, and/or Material" with a value behind it.
No biggies here, maybe just a bit irritating.
I will fix this tomorrow. If you want the be rid of the errors - install the 1.52 STABLE release.
Erick
Oki, thanks.
... btw, did you mean 1.50 Stable?
I have refreshed the installer at the top of this thread with:
1.52.0.27
- Fixed issue where materials could not be pasted following the 1.52.0.25 change to allow pasting of disconnected nodes
1.52.0.26
- Disabled sliders when the edit value is < 0 (to allow negative UV_Scales from Poser Image_Map nodes.
Erick
Update works great so far.
Thanks! :mrgreen:
Return to “Poser”
