hi!TheJester87 wrote:Since the update the Octane Live Database doesn't populate any materials. Nothing is there when I select the Live DB tab.
the 1.2 update moved the livedb cache database to a new location and also the stored data is in another format; normally the installer also copies a prefilled cache database with all the materials available @ around the time the installer was built, so it shouldn't be empty.
one thing you could try is to delete the OctaneRender_livedb.oczdb file in the C:\Users\*Profile*\OctaneRender\Data folder, and run the full installer once again; note: the full installer now also always contains the latest plugin version (the update installer is only needed for subsequent updates)
what you also may try is to just update manually by clicking the "update now" button in the preferences tab.
pls let me know if and what of these worked...
