Here is a newer version with better manners.
Will behave more elegantly when you cancel the script mid render.
Names files with the number of samples and time to render appended.
Shortcut Key added (ctrl + B)
Upon completion, main window remains visible with total time (seconds) to render entire batch displayed.
Render and save to PNG all render targets
- Batch Output RenderTargets.lua
- (10.42 KiB) Downloaded 631 times
Probabaly, there is no code to handle anything in groups.
Guys,
Your help and work is far beyond my expectations.
Thanks you again.
Thanks you again.
Would it be possible to have a check box option type of thing for whether you want to add the "01" or "02" at the end of the image when it is saved?
I would rather it just save the image as my render target name and not add anything.
It looks like I can just edit that on the script myself to not do it (maybe, I'm no programmer), but I would much rather just keep using any updates posted here instead of using my own version.
Kavorka,
Of course having an option like that is possible, if you don't check it however, and then export a batch of render targets where all names are not unique, you will end up overwriting one or more of them which could be pretty annoying. The numbers guarantee that file names are unique regardless of what silly things a user might instruct the software to do. It is also faily easy for you to remove the number appended to the file name in the script.
I have another question, should there be an option to ignore the max samples value if a kernal node is attatched to the render target, this way you could do differnt numbers of samples depending on what type of kernal is being used.
best
Mark
best
Mark
That makes sense.
The only reason why I asked for that is because I will be rendering ~80 images this weekend with the script. But, I'll just rename them after. For any other project, its not actually a problem.
Is it possible to add a pause button?
Right now there is no way to pause once you start.
If you are rendering lots of images (like me) or a couple that take several hours, your GPUs are tied up for a while.
Thanks for this awesome script, just tested it with the first 8 images and it went great!
- stratified
Hi guys,
First of all thanks to Mark for improving this script. It was a massive effort to add a user interface to this script!
I modified the script a bit:
Some general tips for script writers, things I noticed when looking through user's scripts (not only yours Mark, don't take it personal
cheers,
Thomas
- Detect render targets nested in a nodegraph.
- Allow to select which render targets should be rendered in the batch.
- assign an index to each render target and use that one in the output name (instead of the render time), this prevents overwrites as well. (Ofcourse it's stupid to have 120 render targets named "Render Target" in the first place).
- Don't use tabs in your scripts, configure your editor to emit 4 spaces for a tab (the editor in Octane does this automatically).
- Respect the indentation, it's hard for others to read your scripts if everything is jumping around.
- We have shortcuts for
getProperties()andupdateProperties, you can usenode.nameorbutton.enableinstead. - Setting the width on a table is counter productive, they are designed to calculate their width for you.
cheers,
Thomas
