FOG interaction with Portal On - Off comparison
Moderator: BK
linvanchene
edited and removed by user
DrHemulen
I've also been playing around with portals, without much luck. A couple of observaitions on your experiments, based on my undertanding of the manual:
* Portals should be planes with their normals pointing into the room, not boxes
* ALL windows must have portals for the effect to work
What I did was duplicate the windowglass plane in blender and flip the normal and then reimport into DAZ. Couldn't see much of an effect when toggeling it on/off :-/
Maybe we should pick a simple scene (with one window) to run tests on. Then we can share .obj files with portal planes for consistancy.
GTX 780, 6 gigs of VRAM - Win 7 Home Premium 64 bits
linvanchene
birdovous
If I remember correctly there was also some sort of an issue with the actual glass pane in the window which, if there was a portal polygon/object used, should be turned off (the glass I mean).
Birdovous
Master: Core i7 2600K, 32GB RAM, 2x EVGA GTX Titan X (SC)
Slave 1: Core i5 4460, 16GB RAM, 2x EVGA GTX 1080 Ti SC2
Slave 2: Core i7 9700K, 64GB RAM, 2x ASUS RTX 2080 Ti
linvanchene
Isotemod
I always thought portals just terminated ray tracing attempting to go the wrong way through the plane resulting in less wasted time calculating bounced light that left the interior of your "room"
DrHemulen
Ok, I made a simple little box with a hole and matching plane to try this out. They are attached as .obj files if anyone wants to play around with them. Import with Hexagon prefs to fit Genesis scale.
The plane fits the hole in the box extactly. Import it twice if you also want some glass. Normal is pointing into the box.
I don't see a noticable difference between portal on and off :-/
linvanchene wrote: Update / Edit:
I adjusted the window material to diffuse, floattexture and opacity 0.
Still the same result: Image with Portal labeled OFF renders a lot brighter than with Portal labeled ON.
How does it look compared to NO portal?
room.obj
(682 Bytes) Downloaded 163 times
DrHemulen
And the plane.
plane.obj
(271 Bytes) Downloaded 183 times
linvanchene
DrHemulen
PMC or pathtracing, they looked identical to me. I guess the very high contrast is because octane is photorealistic, not "vision" realistic, a photograph under similar circumstances would look kinda like that, unless you start on HDR shenanigans.
Return to “DAZ Studio”
