when i launch octane plug in i can see the objects in my scene even if there are no lights,
i don't know where this light comes from and how to shut it down,
i want a spot light to brighten just a small part of my scene and i want everything else to be black. how can i do that?
thx!
simple light question
Best is a sample scene. Also pls check manual and other samples
- light-sample.rar
- (111.58 KiB) Downloaded 232 times
- turtles123
ok so if i understand right i must use a octanesky and on the enviroment tag set power to 0.0001
thx!
thx!
yes right, plugin need a light source. If you are not creating and sky object or daylight, it will create a environment with gray texture. Last versions have a command as Octane dialog->File->Edit in Standalone. This is for opening the scene in Octane Standalone. This maybe usefull to see structure of exported scene
