Hello
The possibility of making groups is great and dramatically reduces the caos in a scene.
But I am trying to setup a batch render and cannot render target nodes that are inside groups. How can I do this?
Kind regards
Filipe
Batch rendering a target node inside a group.
Are you using Lua? If yes, you need to fetch the render targets with this command, you should be able to get all render targets with this command (note the second parameter ofmanalokos wrote:Hello
Kind regards
Filipe
:findNodes()
allRenderTargets = octane.nodegraph.getRootGraph():findNodes(octane.NT_RENDERTARGET, true)
Yes, it seems that is currently not possible. We will fix it in the next release.manalokos wrote:Hello
I am using the command line rendering using a .bat file.
so, if I understood good (from answer), we'll still be able to use command line, not only Lua?
Sure, why not? Now, you can also run Lua scripts via the command line, but you can stick to the old command line arguments, if you want.glimpse wrote:so, if I understood good (from answer), we'll still be able to use command line, not only Lua?
Great! for some reason I thought that Lua is going to be the only option to do batch =)abstrax wrote: Sure, why not? Now, you can also run Lua scripts via the command line, but you can stick to the old command line arguments, if you want.
Any example of Lua from command line you can share?abstrax wrote:Sure, why not? Now, you can also run Lua scripts via the command line, but you can stick to the old command line arguments, if you want.glimpse wrote:so, if I understood good (from answer), we'll still be able to use command line, not only Lua?
- stratified
You can run your scripts withTugpsx wrote:Any example of Lua from command line you can share?abstrax wrote:Sure, why not? Now, you can also run Lua scripts via the command line, but you can stick to the old command line arguments, if you want.glimpse wrote:so, if I understood good (from answer), we'll still be able to use command line, not only Lua?
octane.exe --script C:\PATH\TO\myScript.lua
. There's no difference with the normal lua scripts (although, Octane is started with the default project).cheers,
Thomas
