OctaneRender for AutoCAD Beta 1.20.1 [OBSOLETE]
Autodesk AutoCAD (Integrated Plugin developed by OTOY, maintained by Paul Kinnane)
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for AutoCAD, build 1.20.1 (STABLE RELEASE). This version is compiled against Octane 1.20, so see the requirements for that build regarding compatibility with your video card.
The plugin requires AutoCAD 2013 or 2014, Windows 32bit or 64bit.
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- AutoCAD version and build number
- OctaneRender for AutoCAD version (ie. 1.20.1.10)
Change Log from release X.XXa
- N/A
For more information...
- Read the on-line manual
- Read the FAQ
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Download the plugin from the following links:
- Current version available from your Downloads page.
guillerodriguezv
Hi, it would very useful to make the autocad plugin support for AEC objects (MEP,Architecture Objects). It is not practical when you make a change to the original file and then converted to solids, you had to start all over again with the textures, please check this suggestion for the final release.
Laptop- Win 10 64- 32 Gig GTX 880m 8 Gig - Desktop Win 10 64- 16 Gig GTX 980 ti 8 Gig
I agree - however there is no facility in the AutoCAD API to extract AEC object geometry. The only way to get vertices is to convert to solid - so unfortunately this is a necessary step.
If you want to not loose your textures, then use the Octane material "Save as Default" feature in the plugin for each of the AEC object material name - so when the plugin next encounters those material names, it will use the Octane setup you saved.
perro_abombao
Demo when?
Demo when?
Hi - I will build a demo version against the latest Octane 1.31 engine later this week. I will post in this thread once it is available for download.
The demo version is now available - download from http://render.otoy.com/downloads.php.
perro_abombao
face_off wrote:The demo version is now available - download from http://render.otoy.com/downloads.php.
Thanks!!!, sorry, I have a proplem.
Ah, sorry. I will fix this and post back here when the download is ready.
The fixed demo version has now been posted at http://render.otoy.com/downloads.php.
perro_abombao
thanks....!!!!
Return to “Autodesk AutoCAD”
