Thanks, that sounds awesome3dmania wrote:I will add a new DUF File this weekend with multiple SSS Setups which can then be saved in your presets. Perhaps even make a new topic which can be stickied.
Moderator: BK
well, yes and no. imo it is not that bad already, there is a good number of really good mats, and lots of starting points for tweaking and own experiments.voon wrote:Hm .. I find it sad that LiveDB is living such a shadowy life. It's a great idea, and if what you describe is causing real showstoppers, then I suggest fixing those? A solid Material DB would just rock (or glass or metal shine ..).
in a way, yes. when octane was first developed, integrated plugins were far away, and the node system internals had some insufficiencies in that direction. otoy devs did completely rewrite this part from last summer on (as you may be awara - big undertaking), so this is about to change in the future.voon wrote:Why is that? Technical problem?t_3 wrote: one reason why there is a little lack in updates lately might be, that more and more ppl are using plugins for main work, and you currently can't upload materials out of plugins.
i meant that plugins were not able to uses the common .ocm format to export or import single materials (for the same reason live db uploads were not possible)...voon wrote:You mean export into a file? In Octane I guess you can just modify anything imported from livedb and upload it? I never tried, though.t_3 wrote: this plus missing export/import abilities for single materials...
