OctaneRender™ Standalone 1.31
Rikk The Gaijin
abstrax wrote:
Rikk The Gaijin wrote:I also have another problem (it seems Alembic support is completely screwed) :?
Could you post an example file and a screenshot how it appeared in previous versions and in 1.31? Thanks.
I tried in version 1.29, 1.28 and 1.27, all have the same problem... Does anybody use Alembic? How come nobody ever found this problem?
Last edited by Rikk The Gaijin on Wed Feb 12, 2014 8:45 am, edited 1 time in total.
abstrax
Rikk The Gaijin wrote:What about my alembic problems?
See http://render.otoy.com/forum/viewtopic. ... 42#p170642
Rikk The Gaijin
Sorry, I edited my previous reply
Rikk The Gaijin
Please check the attached file. It contains both the Maya scene (Maya 2014) and the .abc file.
When imported in Octane (any recent version) you will see that the camera is wrong, and the materials are not exported correctly.
teeth_test.zip
(445.94 KiB) Downloaded 186 times
pixelrush
>Increased the maximum render resolution to 32768x32768 pixels. Please be aware that you can't...
well that's a useful improvement then... :roll:
I really wonder about the wisdom of adding stuff that cant be used and will fail with no error handling.
Maybe put a small vram use note on the resolution panel and a note about using opengl over 8k?
Plenty of space there :geek:
16k x (8)/16k ought to fit in (3/4)/6GB cards perhaps you should add these to the presets while you are about it.
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
funk
abstrax wrote: [*] Fixed creation of object layer pins of a scene node graph when loaded from Alembic files.[/list]
Thanks for the quick fix guys!
funk
Rikk The Gaijin wrote:I tried for the first time to export a camera from Maya in alembic format, and I can see the blue circle representing the camera node in Octane, but the camera settings are completely wrong compared to the ones I have in Maya... Am I missing something? :?
Btw, version 1.31 looses the material information of Alembic... Works fine in previous versions.
You need to add a render node, then connect the camera and scene geometry to it
Also about the materials... Roeland stated that most 3d apps exports alembic materials incorrectly right now
http://render.otoy.com/forum/viewtopic. ... ic#p164288
Rikk The Gaijin
funk wrote:You need to add a render node, then connect the camera and scene geometry to it
Thank you funk, this solves the camera problem! ;)
However the material is incorrectly exported in any previous version, and the node is completely missing in 1.31.
Any suggestion? I've attached the scene files in the post above, can anyone try it? :?
BorisGoreta
If I have an environment sphere emitting a HDRI map then emmission intensity gets normalized according to the sphere size. Since environmet sphere is usually really big emission strength gets really weak because of this normalization and my HDRI environmet is barely visible. Could you please turn this off or make it an option ( also available in plugins please ).
Dmi3ryd
Please fix automatic length alembic node (now is too large) and distance between point is too large
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
