OctaneRender™ Standalone 1.30
I've problem with alembic animation. Could not render my project (((
- Untitled-1.png (9.16 KiB) Viewed 3639 times
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
Ok thanks for the feedback. Keep it coming, because it looks like there will be a small update tomorrow to fix some deal breakers.
abstrax thanks!
- BorisGoreta
- Contact:
What did you get about texturing instances ? I am interested in this topic ? Is it possible to make variations to instances in a manneer that each instance is different color ? One is totally red, the other green and so on.
smicha wrote:Now I get itIt works like a charm.
Thank you so much!
BorisGoreta wrote:What did you get about texturing instances ? I am interested in this topic ? Is it possible to make variations to instances in a manneer that each instance is different color ? One is totally red, the other green and so on.
Thank you so much!
Yes Boris - you may even mirror instances and have unsymmetrical texture on them. I'll post some screenshots here soon.
Here is the screenshot - just use the material map (menu->geometry) for each instance and define colors, textures independently.BorisGoreta wrote:What did you get about texturing instances ? I am interested in this topic ? Is it possible to make variations to instances in a manneer that each instance is different color ? One is totally red, the other green and so on.
roeland wrote:Maybe it is something in your default scene. Can you go to %appdata%\OctaneRender and rename the defaults.ocs file? If this solves the problem can you attach this file so we can fix the crash?
Roeland
Roeland
I can't find a defaults.ocs file anywhere on my laptops c drive, the drive where octane is installed,
this morning i did install release 1.30 on my desktop and it worked fine.
best
Mark
