OctaneRender™ Standalone 1.30
Dmi3ryd
I've problem with alembic animation. Could not render my project (((
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
abstrax
Ok thanks for the feedback. Keep it coming, because it looks like there will be a small update tomorrow to fix some deal breakers.
Dmi3ryd
abstrax thanks!
BorisGoreta
What did you get about texturing instances ? I am interested in this topic ? Is it possible to make variations to instances in a manneer that each instance is different color ? One is totally red, the other green and so on.
smicha wrote:Now I get it :oops: It works like a charm.
Thank you so much!
smicha
BorisGoreta wrote:What did you get about texturing instances ? I am interested in this topic ? Is it possible to make variations to instances in a manneer that each instance is different color ? One is totally red, the other green and so on.
Thank you so much!
Yes Boris - you may even mirror instances and have unsymmetrical texture on them. I'll post some screenshots here soon.
smicha
Here is the screenshot - just use the material map (menu->geometry) for each instance and define colors, textures independently.
User avatar (Default)
merid888
thank you karba, i'll test
regards octanerender team
roeland
If you want to instance meshes, it is usually the easiest to copy and paste the mesh nodes. All mesh nodes loaded from the same file are always considered instances.
Roeland
Eznit
Thanks for the update 1.30 :D
MB
roeland wrote:Maybe it is something in your default scene. Can you go to %appdata%\OctaneRender and rename the defaults.ocs file? If this solves the problem can you attach this file so we can fix the crash?
Roeland
Roeland
I can't find a defaults.ocs file anywhere on my laptops c drive, the drive where octane is installed,
this morning i did install release 1.30 on my desktop and it worked fine.
best
Mark
