yes tested with GTX780 ti & GTX 660 ti all working great this end. color picker works great
no errors found at this early stage
OctaneRender® for Poser (Windows) - build 1.29 [OBSOLETE]
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
If Standalone is working with the Titan, the plugin should. There is something else going on here....Any more ideas?
What Nvidia drivers are you using? If it's 331, there are know issues with these drivers, and it would be worth trying 327.
EDIT: Also worth making sure you have not overclocked either of your cards. You are running 2 right? Make sure SLI is disabled.
Driver version 332.21 ... suppose I could find an older driver and try that.
RAM: 64GB
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
RAM: 64GB
Hold off for a bit - see if anyone else reports the issue. Give it 24 hrs...Driver version 332.21 ... suppose I could find an older driver and try that.
Yeah good idea... 3.27.23 of the driver spat the dummie and said.. Nah!
RAM: 64GB
RAM: 64GB
I am running 332.21 and everything seems to be running fineface_off wrote:Hold off for a bit - see if anyone else reports the issue. Give it 24 hrs...Driver version 332.21 ... suppose I could find an older driver and try that.
This is in my new machine with a Quadro K2000 as my main display and 2 Titans for GPU rendering
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
When trying to do an animation with my "Mountain lion scene", I get this cuda error:
Started logging on 27.01.14 14:45:48
OctaneRender version 1.28 (1280000)
CUDA error 1 on device 0: One or more of the parameters passed were not within an acceptable range of values.
-> Failed to launch kernel (clear)
CUDA device 1: Invalid device memory for texture
CUDA device 1: Failed to set up film for tone mapping
CUDA device 1: Failed to run tone mapping
Snip from the logfile:
DEBUG:root:creating new scatter node
DEBUG:root:loading transformation matrix from C:\TempGrass_lion\tree.csv
DEBUG:root:transformation matrix loaded with 50 rows
DEBUG:root:setting float array for scatter node
DEBUG:root:deleting float array
DEBUG:root:Scatter node for Tree-Ash-3_1 created
DEBUG:root: Mesh node for Tree-Ash-3_1 created
DEBUG:root:Opening Viewport - setting rendertarget
DEBUG:root:Cuda Error : CUDA error 1 on device 0: One or more of the parameters passed were not within an acceptable range of values.
Zay wrote:When trying to do an animation with my "Mountain lion scene", I get this cuda error:
Nice... but not nice to see it happening with someone else, thought it was just me for a while there.
RAM: 64GB
RAM: 64GB
