OctaneRender® for Poser (Windows) - build 1.29 [OBSOLETE]
I have refreshed the installer at the top of this thread with:
1.28.0.18
- Compiled against Octane 1.28
- Added "Lock" checkbox for scale sliders in the Node Edit box
- Added Configuration option to specify where LiveDb texturemaps are stored
- The above LiveDb texturemap location is also where compress texturemaps are stored from the Compress Texture Maps script
- Added White Balance color picker (I love this!)
- When performing any function with "Retain Existing Imagemaps" - now ONLY THE IMAGE MAP is retained. The power, gamma, invert, transform, projection, etc are now replaced by the pasted material.
- Added configuration option to set the default "smooth" pin value. Set to OFF if you have a scene with lots of flat architectural surfaces. Does not apply to skin materials - which will always have smoothing ON.
- Fixed issue where clicking on a Poser material in the Material Room as selecting the figure/prop in the plugin Material tab rather than the material
RGUS
27_01_14 - 1_28_0_18 - ERROR_002.jpg (6.49 KiB) Viewed 4089 times
face_off wrote:I have refreshed the installer at the top of this thread with:
1.28.0.18
Love that White Balance thing too Paul... however...
Apparently my Titan card doesn't like this version... attached...
octane 1.28 140127 181900.log
(983 Bytes) Downloaded 216 times
27_01_14 - 1_28_0_18 - ERROR1.jpg (9.27 KiB) Viewed 4089 times
RAM: 64GB
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
RGUS
Oh and here's the log file...
Started logging on 27.01.14 17:44:53
OctaneRender version 1.28 (1280000)
CUDA error 1 on device 0: One or more of the parameters passed were not within an acceptable range of values.
-> Failed to launch kernel (clear)
RAM: 64GB
Hi Deane - can you trying again after rebooting - just to make sure everything is clear.
Does Octane Standalone 1.28 work for you?
RGUS
Rebooted... just to clear things... same issue... but now when I change materials from the Live DB... this...
Started logging on 27.01.14 18:29:33
Node type 20005 is either unknown, a linker or incompatible to static pin 'min' (P_MIN, type PT_TEXTURE) of node 'Gradient' (NT_TEX_GRADIENT, 000000004267CA20)
Tried to access null item
We can't evaluate items of a different version (version 0)!
Node type 20005 is either unknown, a linker or incompatible to static pin 'max' (P_MAX, type PT_TEXTURE) of node 'Gradient' (NT_TEX_GRADIENT, 000000004267CA20)
Tried to access null node pin
Node type 6 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000000D7017D0)
Node type 20005 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000000D7017D0)
Node type 20002 is either unknown, a linker or incompatible to static pin 'scale' (P_SCALE, type PT_FLOAT) of node '3D Transformation' (NT_TRANSFORM_3D, 0000000071708280)
Node type 20002 is either unknown, a linker or incompatible to static pin 'scale' (P_SCALE, type PT_FLOAT) of node '3D Transformation' (NT_TRANSFORM_3D, 0000000071708580)
Node type 20005 is either unknown, a linker or incompatible to static pin 'min' (P_MIN, type PT_TEXTURE) of node 'Gradient' (NT_TEX_GRADIENT, 000000004267CC60)
Node type 20005 is either unknown, a linker or incompatible to static pin 'max' (P_MAX, type PT_TEXTURE) of node 'Gradient' (NT_TEX_GRADIENT, 000000004267CC60)
Node type 20002 is either unknown, a linker or incompatible to static pin 'scale' (P_SCALE, type PT_FLOAT) of node '3D Transformation' (NT_TRANSFORM_3D, 00000000425E4E80)
Node type 20002 is either unknown, a linker or incompatible to static pin 'scale' (P_SCALE, type PT_FLOAT) of node '3D Transformation' (NT_TRANSFORM_3D, 00000000425E4B80)
27_01_14 - 1_28_0_18 - ERROR_003.jpg (11.56 KiB) Viewed 4083 times
RAM: 64GB
RGUS
Renders fine in Octane 1.28... with material change... getting a nice pink now on the swimsuit instead of that dull blue.
RAM: 64GB
Thanks - suggest you revert back to the previous version. I just doubled checked the installer and all looks OK.
Can others who have downloaded 1.28.0.18 indicate if it is or is not working for them pls?
RGUS
Reverted back to previous against Standalone 1.28 and all working as expected. But without Whit balance... boo hoo!!
RAM: 64GB
I just downloaded and installed, and it's working fine for me. Maybe your download got corrupted, or the install glitched. Can you pls re-download and re-install and see if that fixes the problem.
And if the problem persists - is it happening with the default Andy scene in Poser?
RGUS
OK... cold start reboot... you know... shut down... power button to turn on.
Downloaded the update again... installed against Standalone 1.28
Loaded Poser and the scene I've been dickin' with... girl in next to nothing... you know normal Poser scene for me.
Fell over...
Reset Poser to defaults... loaded this very skinny guy Andy...
Did 'Refresh Octane scene from Poser'...
Fell over...
with same errors...
Must be that bloody Titan card... you've finally written software Paul that out does nVidea
Any more ideas?
RAM: 64GB
Return to “Poser”
