Alembic and material assignments
roeland
So you imported an Alembic file, only to get a single material input called "Material"? You can disable merging of materials, but now you have 100's of input pins for all the objects in your scene. At least we can give every object its own material.
Oh dear. If only we could make it look like this:
Today we will wrap the Alembic node into another node graph, and then we can hook up all inputs which should have the same material with one input linker of our wrapping node graph, so we avoid a lot of spaghetti on the outside.
Download the entire script here:
Material assignment graph.lua
(2.44 KiB) Downloaded 1010 times
You will see the names of the objects in the input pins of the Scene node, suffixed with "-Material". 3D-applications usually use some pattern to name these objects, so we can use a script to recognize these patterns and hook up the linkers automatically.
At the top of the script there is a function which gets the name of a material input on our Alembic scene node, and it returns which material name we want to assign to it. You may have to adapt it to your specific file.
In our case the Alembic file came from Cinema 4D. It will add a sequence number and the "Shape" suffix to object names. Octane adds a dash and the default material name, "Material". Our function chops all the extra pieces off and uses the original object name as material input. This way all objects with the same name in Cinema 4D get the same material in Octane.
function getMaterialInputName(name)
    -- These are Lua patterns. See <http://lua-users.org/wiki/PatternsTutorial>
    -- chop off the "Shape" and "-Material" parts
    name = name:gsub("Shape%-Material$", "")
    -- chop off any sequence numbers
    name = name:gsub("_%d+$", "")
    return name
end
We get our node graph from the selection, and check if it is not in the root node graph. (use the "Group item" feature in the context menu to automatically wrap the alembic scene).
local scene = octane.project.getSelection()[1]
if not scene or scene:getProperties().type ~= octane.GT_GEOMETRYARCHIVE
    or scene:getProperties().graphOwner == octane.nodegraph.getRootGraph() then
    octane.gui.showDialog
        type  = octane.gui.dialogType.BUTTON_DIALOG,
        title = "Metal.",
        text  = "Please select a scene inside a node graph. If your scene is"..
        " in the root node graph wrap it using the \"group items\" feature.",
    return
end
local parent = scene:getProperties().graphOwner
Then we look if our parent graph already has material inputs so we can recycle them. This way if you reload the file and it gets some new inputs you can run this script again without losing the connections into the inputs of the parent graph.
local links = {}
for _, l in pairs(parent:getInputNodes()) do
    local prop = l:getProperties()
    if prop.type == octane.NT_IN_MATERIAL then
        links[prop.name] = l
    end
end
local used = {}
Now we loop over the material inputs of the Alembic scene and use our getMaterialInputName function to decide what material assignment it should get. If possible we recycle an existing input node, otherwise we have to create a new one. We also put them into a nice row above the alembic scene node. Remember the positions of the linkers decide the order of the input pins of the parent graph.
for _, l in ipairs(scene:getInputNodes()) do
    local name = getMaterialInputName(prop.name)
        if used[name] == nil then
            used[name] = links[name]
            links[name] = nil
                used[name] = octane.node.create{type=octane.NT_IN_MATERIAL, name=name, graphOwner=parent}
            end
            used[name]:updateProperties{position=pos}
            pos[1] = pos[1] + 100
        end
        l:disconnect(octane.P_INPUT)
        l:connectTo(octane.P_INPUT, used[name])
    end
end
We may have some existing linker nodes left which didn't get hooked up to anything. As a finishing touch we just add them at the end of the row. If there are no materials embedded into the input pins corresponding to these input linker nodes you may delete these extra linkers afterwards.
Roeland
thanks roeland ;)
it works smoothly, another weapon in the lua arsenal ;)
ciao beppe
glimpse
thanks Guys for putting all this info! =)
César
I don't understand, how can you know wich material link to the objects when Alembic don't support materials ?
In addition, the script don't work with the Standalone 1.36.
Witwatersrand
Hey guys
Using Octance 2.32.2 and I am getting an error when using this script .
[String "Material assignment graph.lua"]:26: attempt to call field 'getRootGraph' (a nil value)
Is there an update in the script needed or did I just not use it correctly?
Kind regards
Angus
Octane 2.03 : Mac Book Pro Retina, 16 Gig Ram, Nvidia 640m gfx, Octane 2.03. Dell T5500, 32 Gig Ram, Nvidia Quadro 4000
stratified
Witwatersrand wrote:Hey guys
Kind regards
Angus
In subsequent versions getRootGraph() was renamed to getSceneGraph(). If you change this on line 26, it should work.
cheers,
Thomas
Hi, it seems that this script gives some issues again :roll:
Here is a modified version that get one material per geometry name, I had to change the chop pattern from "-Material" to "-Diffuse material" because C4D now use this pattern.
I had to quote the getSceneGraph for make it working. Anyway, the abc materials pins are still there :roll:
if not scene or scene:getProperties().type ~= octane.GT_GEOMETRYARCHIVE then
    --or scene:getProperties().graphOwner == octane.nodegraph.getSceneGraph() then
        title = "Metal.",
    return
end
    -- chop off the "-Diffuse material" parts
    name = name:gsub( "-Diffuse material", "")
    name = name:gsub(" %d+$", "")
    return name
end
local links = {}
    end
end
local used = {}
local pos = scene:getProperties().position
pos[2] = pos[2] - 100
pos[1] = pos[1] - 100
    print (name)
            links[name] = nil
            end
        end
    end
end
for _, l in pairs(links) do
    l:updateProperties{position=pos}
end
ciao beppe
Return to “Lua Scripting”
