invert falloff values
marchermitte
Hello! I'm strugling with this very simple problem, I need to apply the falloff node to a emiter via textured emision node but I need to invert the value (brighter in the middle, darker outside) but the invert node deosn't do the job, neither the clamp node with max value = 0 and min =100.
Any idea?
Thank you!
Marc Hermitte
Intel I7 4.5 Ghz, 24 gig ram, 2x Nvidia GTX 480, win 764bits
juanjgon
This is a good question. The same problem is there in the Standalone app. Anybody know why? ... perhaps you should ask in the main forum.
marchermitte
Ok, thank you Juangon. I just did. I'll let you know if I get any answer.
I'm doing a series of light designs and I need to find a good way to mix emision and subscattering. Subscattering with a light source inside the mesh works nicely BUT I don't get any light affecting the surronding objects.
Marc Hermitte
roeland
This is because although the emitter is darker at the edges, it is still bright enough to saturate the image. You have to decrease the power of the emitter and decrease the skew factor to have visible dark edges.
Roeland
marchermitte
Ok, I tried what you said but still, the effect is very weak.
I'm trying to make a silicon shell light, (with a very organic shape)which works nicely with SSS and a light source hidden in the middle of the mesh but if I do that, I don't get the effect of the light onto the surronding objects. Texture emiter works to a certain extend but I can't modulate the brightness the way I want. I'd like the incidence faloff to be more controlable. Any idea how I could achieve that?
See in the picture, only sss, light doens't affect the table.
Marc Hermitte
roeland
You can definitely see the effect on the book and the Buddha stature. The key issue is not how you construct the light source but more how bright it is. If the light is less bright then you are able to see details like darker rims at the edges, but you won't have as much illumination. If the light is brighter then of course you see more illumination, but the light source itself will just saturate to white in the image.
What you can try is to render an image with only the silicon shell light turned on, or give it a bright color you can recognise, and see where the illumination goes.
Roeland
marchermitte
Ok. Thank you for the advices.
Marc Hermitte
Return to “Lightwave 3D”
