Crash when Combining mix materials in C4D plugin
did you get crash on you created materials? Or it's with only livedb mats?
OK. Just had time to test this.aoktar wrote:did you get crash on you created materials? Or it's with only livedb mats?
Creating my own materials, with material preview on, when combining two mix materials into one mix material, it crashes the second i load the second material.
With Material Previews off, it works fine.
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
Can you check with this version?
http://render.otoy.com/customerdownload ... -1.08a.rar
Been unable to work with this project past few days...
I've been using live db materials. I've tried both Cooper old, and moon metials. (both have a mix material within a mix material)
I've also tried my own materials based on live db materials. Get crashes either way.
However, I'm not sure how to turn off material previews... As long as I can see the materials updating in the live viewer, and prevent crashes, then great.
Also, links to 1.08a seem to not work. Will 1.08a be compatible with older projects?
Win7 64bit
i7 3930k, 64G Ram
2 Titans
1 690
i7 3930k, 64G Ram
2 Titans
1 690
In the Octane Dialog window, go to the Updates menu and uncheck Material Previews. I believe 1.0 final fix's this issue, but i have not tested it yetEdCast wrote:Been unable to work with this project past few days...
OK. I can confirm that it still crashes when mixing 2 LiveDB mix materials into one mix material. As soon as the second slot is loaded.
Turning off material preview still fix's the problem. So just do that for now.
should be fixed, i have tested for mixed materials.
crashed when i tried it. 1.00 Final, r15, Win8aoktar wrote:should be fixed, i have tested for mixed materials.
Thanks for material preview menu!
Yes that worked, turning off material previews.
I installed 1.0, and as soon as I download the material - copper old - from live db, I get a crash.
All I have open is the L-shape studio from Octane render pack. Then I open up live db, get that copper old and I get an instant crash.
Win7 64bit
i7 3930k, 64G Ram
2 Titans
1 690
i7 3930k, 64G Ram
2 Titans
1 690
can you try with this? there is a confusing possible
http://render.otoy.com/customerdownload ... 5-1.01.rar
