obj loader script
Forums: obj loader script
obj loader script
Postby Davve » Fri Jan 03, 2014 4:52 am
Davve Fri Jan 03, 2014 4:52 am
A script that loads obj files from a directory and hook them up to an geo group node.
/David
path = "C:\\your path\\"
cmd = "dir " .. path .. " /b /a"
objFile = {}
nObj = 0;
for dir in io.popen(cmd):lines() do
s = string.lower(string.sub(dir, -4))
if(s == ".obj") then
nObj = nObj + 1
objFile[nObj] = dir
print(objFile[nObj])
end
end
root = octane.nodegraph.getRootGraph()
group = octane.node.create{type=octane.NT_GEO_GROUP, name="Group", groupOwner=root, position={400,300}}
group:setAttribute(octane.A_PIN_COUNT, nObj, true)
for i=1,nObj do
    mesh = octane.node.create{type=octane.NT_GEO_MESH , name=objFile[i], groupOwner=group , position={300 + i*50,230}}
    mesh:setAttribute(octane.A_FILENAME, path .. objFile[i], true)
    group:connectToIx(i, mesh)
end
Davve
Re: obj loader script
Postby bepeg4d » Sat Jan 04, 2014 5:04 pm
bepeg4d Sat Jan 04, 2014 5:04 pm
hi davve, thanks for sharing ;)
unfortunately it doesn't work, at least with 1.24, here is what i get:
ciao beppe
Postby stratified » Sat Jan 04, 2014 10:48 pm
stratified Sat Jan 04, 2014 10:48 pm
Hi Davve,
Thanks for your script! I modified it a bit to make it work for us Linux users. The only catch is that you'll need to install the lua file system library (http://keplerproject.github.io/luafilesystem/manual.html) because we need a portable way to list the content of a directory (We'll probably include this in one of the next versions of Octane because it's really useful). I described LuaRocks in a different post: http://render.otoy.com/forum/viewtopic.php?f=73&t=37632.
Just some remarks, the field groupOwner doesn't exist in PROPS_NODE_ITEM so it's ignored by Octane. When you don't want to position your nodes manually, you can call unfold() on your graph which will layout it nicely for you. Thanks again! here's the code:
-- Generates a group node from the obj files loaded from a directory
-- @description Loads OBJ files from a folder and hooks them up with a group node
-- @version     0.2
-- @author      Davve
-- use the lua file system module
require("lfs")
-- let the user choose a directory
local result = octane.gui.showDialog
    type            = octane.gui.dialogType.FILE_DIALOG,
    title           = "Choose OBJ file directory",
    browseDirectory = true,
    save            = false,
local path = result.result
assert(path ~= "", "invalid OBJ directory")
-- fetch all the obj files in the directory
local objFiles = {}
for child in lfs.dir(path) do
    if (string.lower(string.sub(child, -4)) == ".obj") then
        table.insert(objFiles, child)
    end
end
local root = octane.nodegraph.getRootGraph()
-- create the group node
group = octane.node.create{ type=octane.NT_GEO_GROUP, name="Group" }
group:setAttribute(octane.A_PIN_COUNT, #objFiles, true)
-- create a node for each obj file and connect it to the group
for i, name in ipairs(objFiles) do
    local mesh = octane.node.create{type=octane.NT_GEO_MESH , name=name }
    mesh:setAttribute(octane.A_FILENAME, string.format("%s//%s", path, name), true)
end
-- call unfold on the root graph to arrange everything neatly
root:unfold()
You should see something like this in the end:
group created from all the OBJ files in a folder
cheers,
Thomas
stratified
Postby Tugpsx » Sun Jan 05, 2014 3:35 pm
Tugpsx Sun Jan 05, 2014 3:35 pm
It there an OS detection option, that would allow this to work on PC, Mac and Linux.
Maybe even adding a octane version under the octane.osversion similar to the octane.aversion=123 that would allow a coder to have a script which detects the OS and run the script based on detection.
BTW I had issues getting LFS working on win7 pc, but after a search so did a lot of others.
Dell Win Vista 32 | NVIDIA Quadro NVS135M | Core2 Duo T7500 2.20GHz | 4GB
CyberPowerPC Win 7 64| NVIDIA GTX660Ti (3G) GTX480(1.5G) | 16GB
Tugpsx
Postby stratified » Sun Jan 05, 2014 7:22 pm
stratified Sun Jan 05, 2014 7:22 pm
You can get the current Octane version and the operating system via getSystemInfo(), is this what you're after?
The only reason we're using lfs is to have a portable way of iterating directories. But in the next version of Octane we'll add that functionality.
If we can we'll try to avoid external libraries in our scripts. But for users who aren't distributing their scripts it isn't really an issue.
cheers,
Thomas
stratified
Postby Tugpsx » Sun Jan 05, 2014 8:27 pm
Tugpsx Sun Jan 05, 2014 8:27 pm
Thanks, then its best to leave well alone until next release
Tugpsx
Postby Davve » Sun Jan 05, 2014 11:08 pm
Davve Sun Jan 05, 2014 11:08 pm
Thanks Thomas for your modification.
I must admit that I'm a scripting noob and that it is mainly my brother that created the script, but I'm learning..
I also tried to install the lfs lib without success.
So this version will have to do for us win users for now.
root:unfold() is cool, is there a way to add it as a button in the octane graph?
-- @version     0.3 for windows
-- @author      Davve
    save            = false,
-- fetch all obj files in the directory
objFile = {}
nObj = 0;
nObj = nObj + 1
objFile[nObj] = dir
end
end
group = octane.node.create{type=octane.NT_GEO_GROUP, name="Group"}
for i=1,nObj do
name=objFile[i]
end
root:unfold()
Davve
Postby Tugpsx » Mon Jan 06, 2014 12:19 am
Tugpsx Mon Jan 06, 2014 12:19 am
Nice update, maybe you could also add an option to store last path used octane.project.getCurrentProject or something like that.
Thanks for sharing.
Tugpsx
Postby stratified » Mon Jan 06, 2014 2:03 am
stratified Mon Jan 06, 2014 2:03 am
Hi all,
In 1.25 there will be a function octane.file.listDirectory to get the contents of a directory in a portable way. So LuaFileSystem isn't mandatory anymore. This should work fine in release candidate 1.25.
-- @version     0.3
-- @author      Davve
    save            = false,
local objFiles = octane.file.listDirectory(path, true, false, true, false, "*.obj")
    mesh:setAttribute(octane.A_FILENAME, name, true)
end
root:unfold()
Unfolding can be done in the Standalone version by pressing F2.
cheers,
Thomas
stratified
Postby stratified » Mon Jan 06, 2014 2:05 am
stratified Mon Jan 06, 2014 2:05 am
Tugpsx wrote:Nice update, maybe you could also add an option to store last path used octane.project.getCurrentProject or something like that.
Thanks for sharing.
not sure what you mean, octane.project.getCurrentProject() already exists in the API.
cheers,
Thomas
stratified
Next
Return to Lua Scripting
Mon Mar 08, 2021 4:15 pm [ UTC ]
