Bug[email protected] wrote:I just noticed that... I have a HDRI with 4 light planes, and one of them is ultra bright, what you say is correct, rotation is set to 0, and I see the brightest planebicket wrote: do you notice that environment rotation has gone ? You have to redo the rotation with 2D transform (translate)
OctaneRender® for 3ds max® v1.22a[Test]
- Elvissuperstar007
- Contact:
- [email protected]
so if my value on rotation was 0.071, and other was 0.0
in 2d transformation it should be 0.321 and other 0.0?
if this is correct... I still don't get the same result
@ Elvissuperstar007 - it's not a bug, that object is moved in back by accident, that's why it's darker...
Windows 10 64bit, Intel i5, 32gb Ram, 2x nvidia 1080ti, Driver: 390.77
[email protected] wrote:so if my value on rotation was 0.071, and other was 0.0
Here is my quick test inside 3dsmax
Hi !
I'm testing last build (1.22a), and some object properties features are not working.
Visible to camera On/Off is OK, but all other options are not : visible to reflection/refraction, receive shadows and cast shadows
don't change anything, shadows and reflections are always on.
Can you check this point, please ?
Win7 x64 - 3DSMAX 2019 - 32GB RAM - 1080 TI
Can someone confirm if your IES lights are working or not?
My Portfolio
Guys you can now download my new object visibility floater script.
Thank you again Suvakas for the help.
Hope you all use it for good
Cheers,
http://render.otoy.com/forum/viewtopic.php?f=27&t=37477
Cheers,
My Portfolio
Thanks for your work, I think it will be usefull, but not working for me with shadows and reflections, only visible to camera works.oguzbir wrote:Guys you can now download my new object visibility floater script.
Hope you all use it for good![]()
Cheers,
Maybe you have some idea ?
It doesnt work with reflections. Octane doesn't support it.Dom74 wrote: Thanks for your work, I think it will be usefull, but not working for me with shadows and reflections, only visible to camera works.
I would suggest to test the Cast shadows thing in a simple scene with a single octane light in it.
It should work.
My Portfolio
Do not work ies. Log:
Tried to access attribute via invalid ID A_FILENAME (25)
Tried to access attribute via invalid ID A_RELOAD (89)
Tried to access pin via an invalid ID 1231472128
Tried to access null node pin
Can't read float from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0000000049A72670)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0000000049A72670)
Tried to access pin via an invalid ID 1231472976
Can't read float_3 from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0000000049A72670)
Can't write float_3 to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0000000049A72670)
In 1.22a is not working correctly Mix material. I have returned to 1.18.
Dual Xeon E5520 2.27 GHz, 48 GB DDR III
3ds Max 2016x64, Octane render for MAX, Titan Z
