OctaneRender™ Standalone 1.22
resmas
bepeg4d wrote:
resmas wrote:If anyone can tell me...i think it will be a noob question but :? ...i cant figure it out....How do we render the animation from the alembic? for exemple the "octaneshatter121.ocs" animation...if i want to render it. how can i do it?
Sorry for the most likely dumb question.... :oops:
cheers
resmas
http://render.otoy.com/forum/viewtopic.php?f=73&t=37387
ciao beppe
Thanks Beppe...i will look in to that :o ....for someone (me) that dont understant anything about script.....it will be funny to see how it goes!.... :geek:
cheers ´
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
Elvissuperstar007
bug 1.22
roeland
If an geometry archive doesn't have output pins then it failed to load. Can you check if there are any messages in the log window?
The timeline only shows up when there is animated data in the scene.
Roeland
Elvissuperstar007
roeland wrote:If an geometry archive doesn't have output pins then it failed to load. Can you check if there are any messages in the log window?
Roeland
Started logging on 18.12.13 09:09:28
OctaneRender version 1.22 (1220000)
vipvip
hi,
While testing the 1.22 lightwave plugin version, i've experienced a big loss of performances between the 1.20a and 1.22 version:
it can reach 20% for a PMC scene,depending the scene, so an huge difference !...
I tried further tests with standalone version and it confirmed: the same scene, with the same rendered result, and the same settings ( neutral lighning, no HDRI texture ) gives the following results:
0'46 secs on 1.20a
0'53 secs on 1.22
the % difference can vary between scenes, but generaly, 1.22 is almost each time slower
again, i've noticed this loss on many other scenes while rendering with lightwave (even the smoothness when navigating with the interactive previewer is not as good as the 1.20 version )...
(system: win64, 2 x GTX 780Ti OC, latest NVIDIA WHQL)
smicha
In texture environment and hdri map: TX and TY uv transform values don't work when I input the values from a keyboard. They work only using up and down arrows.
Elvissuperstar007
1.21-1.22 very slow
xxdanbrowne
Conversely I notice a speed increase.
vipvip
xxdanbrowne wrote:Conversely I notice a speed increase.
it would be interesting to have the octane team feedback about that...
Did you try some scene with Pathtracing/PMC render targets ?
bicket
The new projection mapping feature is a great BUT is locked on the world axis => useless in animation.
Will it be possible to have this feature liked to the object ? (I mean if the object move (translate , rotate, scale) the mapping is following the transform)
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
