OctaneRender™ Standalone 1.21
They have infinite (well, very large) max's, so a slider is not valid in this situation.why does Texture/3d Translation not have sliders like for the other values?
ok but why would you want to translate that much?
surely you only want smallish tweaks... unless I am completely overlooking an application for it.
Edit: BTW perspective mapping is pretty trippy to play with
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
Octane v1.55
I guess large range is useful for decals.
- Elvissuperstar007
- Contact:
not highlight element on node
- Jaberwocky
Cheers Marcus
Jaba
Jaba
wow, impressive
a big thanks for the big update
very interesting the new node graph and node system, it's extremely powerful
i have tried to import an alembic scene with a simple camera animation and it's incredible
i have not get the texture but the camera animation is there and playing with the shutter speed is extremely funny
here is a simple example with the old benchmarck scene exported from c4d via alembic
ciao beppe
Thanks for release!
It seems that color linearization of OBJ doesn't work correctly, 'linear' colors look like sRGB and 'sRGB' colors look like double washed out.
Custom separator (comma) doesn't work either.
SketchUp Pro 8/ Maya 2012 / W7 64bit / Intel i7 870 / 8GB / 2*GeForce gtx 680 4GB
bepeg4d wrote: i have not get the texture but the camera animation is there and playing with the shutter speed is extremely funny
ciao beppe
>>> BUG : changing "Shutter time" doesn't update the render until you change "Time"
- Seekerfinder
THAT'S what I'm talking about!! Finally... thanks guys!abstrax wrote: We also replaced the image texture transformations described in the update with a generic projection system, that supports now linear, spherical, cylindrical, perspective, box and UV mapping.
Feature request (belly laugh, I know...) - would be great if one had the option to lock S.X & S.Y. This could be useful for other texture mapping nodes as well.
Seeker
