Stabile version 1.01 (SDK 1.20.3) **** 17.01.14 ****
wetfusion
clicked start render. nothing happen.
intel 17 4770k (MSI MPOWER MAX)
32GB 1866ghz corsair dominator platinum
2x MSI 780 lightning
Plextor M5 256GB
wetfusion wrote:clicked start render. nothing happen.
you plugin isn't working man. Something is wrong. Let's talk from PM.
shawnfrueh
Hey Aoktar,
I am getting this set focus bug now when I open a file with a camera tag in it. Here is a gif of what it does. (This is not rendering nor had the plugin been opened. yet this still happens. RC1)
shawnfrueh wrote:Hey Aoktar,
not bug, it's only some output. Plugin does lot of thing in background, without displaying.
This will be removed later.
TBA3D_70
Thanks for the mac R15 RC1 version :)
Is it possible for future versions, that the "numerical input" is allowed in the dialogs (settings for example).
For now the slider works fine, but if i want to type in a specific number --> the slider won´t update.
Then I can match the number "nearly" with the slider, but not the exact number.
Hope you can fix this for future versions :)
Best regards,
Thomas
blodge
Aoktar -
Getting crashes when opening a scene saved with an older version of the plugin. Disabling the plugin lets the scene open just fine. I've attached the bug report below..
_BugReport.zip
Bug Report
(15.75 KiB) Downloaded 205 times
blodge wrote:Aoktar -
what is versions? And give me the scene for check?
blodge
aoktar wrote:what is versions? And give me the scene for check?
Using RC2. The scene is pretty big so I'm not able to upload it.
possibly the problem is because of any material/texture, but we can open our old scenes without problem
blodge
I rolled back to RC1 to see if that would work. The scene will open in C4D R14 running version RC1, but will not open in R15 running RC1. The file was originally built in R14.
