Help on grass
wetfusion
actually how to do grass in octane? can i still use hair?
picture from google
intel 17 4770k (MSI MPOWER MAX)
32GB 1866ghz corsair dominator platinum
2x MSI 780 lightning
Plextor M5 256GB
glimpse
Depends what You use =) standalone or plugin =) if let's say 3ds max then You can install forest pro, multiscatter, carbon scatter and scatter instances around with the help of those =) if You're on standalone =) You can try phantom scatter =) it's very useful yet very simple program, that will help You to generate coordinates for scatter and export them as .csv file =) then You only need to plug the file in standalone and use desired geometry =)
atome451
wetfusion wrote:can i still use hair?
Yes, hair works with Octane Export and Octane plug-in. You only need to choose the correct type in "generate" tab in Hair object attributes (like triangle or controled extrusion, ...).
It seems Hair works with Octane plug-in only with a polygons selection, not with a whole object in the link of guides. I don't know why...
Sorry, I work with C4D in french, I'm not sure for the technical translations.
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
wetfusion
i give up. any tips for real looking grass? better a tuto :lol:
Plextor M5 256GB
atome451
Hi Wetfusion,
This is the answer. Your plane is still parametric and then you have no polygon selection. In this case, the result is like yours in Octane. ;)
wetfusion
atome451 wrote:Hi Wetfusion,
can you give an example?? thanks for the reply
Plextor M5 256GB
atome451
I've made a very quick sample of Hair with Octane. I hope it'll be usefull. C4D R14.
grass_sample.zip
A very quick sample
(188.73 KiB) Downloaded 354 times
wetfusion
bro thank you so much for the example :)
i manage to do it.
Plextor M5 256GB
