Stabile version 1.01 (SDK 1.20.3) **** 17.01.14 ****
AndreaMannori
@Aoktar: I did try the new release and made a video showing the absence of the gpu-tex-sample stats.
ScreenCapture_OCT_info_HUD.mp4
(3.03 MiB) Downloaded 3593 times
Andrea Mannori
win 8.1 x64; nvidia 770M driver 340.52; octane standalone 2 + c4doctane 2.
renderfarmsrl: thanks, but did you clicked to render area?
Augustronic: Yes, you're correct. Cameratag has a wrong convertion on offset parameters. I'm fixing with new release
Ok, please let's check this for cameratag offset problem:
http://render.otoy.com/customerdownload ... 00-RC1.exe
AndreaMannori
@Aoktar: thanks for the tip, now I can see the stats.
Another problem I have is the one shown in this video. There's a sort of random update of the light and the geometry. In the video you can't see the mesh tag but I experienced issues even with mesh tags on.
Do I have to put a mesh tag onto all animated geometries or only onto the root parent?
animation_issue.mp4
(9.99 MiB) Downloaded 3576 times
Andrea Mannori
renderfarmsrl: i have to say that C4D can't give my expected update detection behaviours sometimes with current algoritms especially for mocloners. But i see that you didn't click the enable of suntag. For updates, to put a tag on top of group is must be enough. But i have restriced some detection to block the unnecessary updates on every click. Sometimes you should put your generator objects under a null, and try to locate tag on null.
And last note, i don't want to spend lot of time on current version for minor problems. After 1.0, we will have better plugin with new SDK.
I have a question to Win8 and win8.1 users. Does anyone can run octane on R15 in W8/8.1 without problem? I need this info.
SVITAdmin
aoktar wrote:Hi,
I have a question to Win8 and win8.1 users. Does anyone can run R15 on W8/8.1 without problem? I need this info.
trying now. on Win 8. C4D hard crashed on our scene using live render window with locked resolution. Had to end task. gonna play with it more now. will report back.
Edit. I think it's because i had no priority set on my display card and it was running full blast, while i was trying to do other things. I noticed that Octane has never liked being messed with if you have all cards running with no priority. Both on Mac and PC. Anyway, so far so good.
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
brasco
aoktar wrote:Hi,
Yes, Windows 8.1 and 8 and R15 run without issue.
edit: To clarify, I'm talking about Cinema 4D R15 running fine, not Octane, which is what I though you were asking :)
cheers
brasc
Rig#1 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 7900K 4.7GHz | 64GB
Rig#2 Win 10 x64 | GTX 1080Ti | GTX 1080Ti | GTX 1080Ti | i7 3930K 4.4GHz | 32GB
Rig#3 Win 10 x64 | GTX 1070| GTX 1070| GTX 1070| i7 2600K 4.8GHz | 32GB
EricDesign
Problem with the activation....
each time I enter my password and user names is crash after close C4D and is not acitvate :oops:
i5 7400 / 2 x GTX980Ti / 32gig ram
http://ericdesign.info
brasco
Just to confirm, 1.00RC1 still crashes on Win8.1.
cheers
brasc
