Which feature do you need the most?
Forums: Which feature do you need the most?
Volumetric: fire, smoke, clouds
351
16%
Hair&Fur
273
13%
Render Passes
232
11%
Particles
215
10%
Mixing of daylight and HDRI environment
205
10%
Multilight
151
7%
Region Render
139
6%
Rounded edges
126
6%
Multi UV channels
124
6%
Undo
102
5%
Internal Texture Mapping (planar, box, spherical, cylindrical, camera and so on)
83
4%
Network render
78
4%
Subdivision surfaces (OpenSubDiv)
78
4%
Total votes : 2157
Re: Which feature do you need the most?
Postby Davve » Fri Nov 22, 2013 2:18 pm
Davve Fri Nov 22, 2013 2:18 pm
Of course hair, fur and subdiv (displacement)!
I would like to add ptex support to the list :)
Davve
Postby manalokos » Fri Nov 22, 2013 3:04 pm
manalokos Fri Nov 22, 2013 3:04 pm
These 3 are the most important:
UNDO
Multi UV channels
Rounded edges
We already have particles, and hair and fur, using particle instancing
volumetric is nice but not that important
render passes for an unbaised renderer, really??
subdivision surfaces? why do it on the renderer and not on the modelling software?
Multilight might be nice!
Region render too, although you can do it by copying the camera and zooming in on the image, and using lenshift
Filipe
manalokos
Postby xoio » Fri Nov 22, 2013 3:59 pm
xoio Fri Nov 22, 2013 3:59 pm
"render passes, really?"
Come on, guys ...
Obviously you can tweak a lot in octane in realtime. But in production there is A LOT you still want to touch in postproduction and some things might effectively not be doable inside octance. I would give a lot for some Multimatte /Object-ID .. we need good masks!
Additionally using FumeFX / Phoenix, we still need to switch to another render. That's ok, but without proper passes it's getting hard.
Seriously it's the main thing that holds us from using this great renderer from usage in production! :shock:
yes, render passes are very much demanded in our studio! If possible in the same go as the beauty pass.
xoio
Postby Karba » Fri Nov 22, 2013 8:57 pm
Karba Fri Nov 22, 2013 8:57 pm
Current state for now
Karba
Postby Refracty » Fri Nov 22, 2013 10:37 pm
Refracty Fri Nov 22, 2013 10:37 pm
I wished Object Motion Blur was on the list ;)
3D Animation & 3D Visualisierung Köln, Germany
www.lichtblickstudio.com
High End CGI, Animation and VFX from Cologne
Refracty
Postby MOSFET » Sat Nov 23, 2013 12:18 am
MOSFET Sat Nov 23, 2013 12:18 am
Refracty wrote:I wished Object Motion Blur was on the list ;)
Karba did mention Motion Blur along with Displacement in the first post of this thread. I assume he meant Object Motion Blur as Camera Based MB will ship with Octane v1.5.
MOSFET
Postby oguzbir » Sat Nov 23, 2013 11:49 am
oguzbir Sat Nov 23, 2013 11:49 am
Karba hi,
I'm one of the people who asks for hair support.
Would you be willing to add Ornatrix hair support as well if hair&fur passes the poll?
In ornatrix hair there is a modifier called OrnatrixVrayMod which enables vray to render hair in it own shader system.
If you step in to add hair&fur function in octane, I wonder if it will be somehow easy to implement Ornatrix as well. I'm guessing you'll have code a hair primitive in octane and it might be easy to implement to other hair plugins. Just like you added support for Forest Pack pro in the past?
@gabrielefx
I render hair not for hairy rugs but anim characters and product visuals.
I really would like see octane perform in hair.
Cheers,
My Portfolio
oguzbir
Postby FrankPooleFloating » Sat Nov 23, 2013 1:56 pm
FrankPooleFloating Sat Nov 23, 2013 1:56 pm
Guys, please don't forget that we very much need Gradients in SDK as well, so plugs can use them.
This should have been in the poll.. unless you were already planning on adding them very soon.
FrankPooleFloating
Postby manalokos » Mon Nov 25, 2013 1:37 am
manalokos Mon Nov 25, 2013 1:37 am
I will be very sad if I see that Octane is straying away from Archviz into the pass of "all the other stuff" that really doesn't need unbiased rendering.
come on... Undo has only 5% votes? What world do we live in, is the user base mainly kids? :shock:
Octane should be the closest to virtual photography, no silly stuff, just plain reality at the reach of our hands, and our minds.
manalokos
Postby Karba » Mon Nov 25, 2013 2:51 am
Karba Mon Nov 25, 2013 2:51 am
manalokos wrote:I will be very sad if I see that Octane is straying away from Archviz into the pass of "all the other stuff" that really doesn't need unbiased rendering.
That is why we make this poll. We can see real situation.
Undo has only 5% probably because users mostly use plugins(not standalone) and they have undo in a host application.
Karba
PreviousNext
Return to General Discussion
Sun Jul 12, 2020 8:26 pm [ UTC ]
