MotionBlur
Forums: MotionBlur
MotionBlur
Postby face » Thu Oct 31, 2013 11:21 am
face Thu Oct 31, 2013 11:21 am
Only a quick test.
It´s also not perfect but shows the right way...
face
http://vimeo.com/user2509578
face
Re: MotionBlur
Postby rgigante » Thu Oct 31, 2013 2:30 pm
rgigante Thu Oct 31, 2013 2:30 pm
Congrats Stephan! Well done!
rgigante
Re: MotionBlur
Postby face » Thu Nov 14, 2013 4:46 pm
face Thu Nov 14, 2013 4:46 pm
More MB and ICE generated UV´s to read it from tools like emPoligonizer/Topolizer...
[vimeo]http://www.vimeo.com/79406559[/vimeo]
face
face
Re: MotionBlur
Postby PeterCGS » Thu Nov 14, 2013 6:32 pm
PeterCGS Thu Nov 14, 2013 6:32 pm
Funky :) Great stuff!
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
PeterCGS
Re: MotionBlur
Postby face » Thu Nov 14, 2013 7:36 pm
face Thu Nov 14, 2013 7:36 pm
The problem you will become with self generated UV´s is when you subdivide your mesh.
That´s because the uv´s vectors are only another selfmade value array in an ICE-Tree and will not subdivide.
You will become then a different between needed and used UV-Values...
face
face
Re: MotionBlur
Postby OneBigTree » Thu Dec 12, 2013 7:55 pm
OneBigTree Thu Dec 12, 2013 7:55 pm
Glad to see mblur on it's way. Well done!
OneBigTree
Re: MotionBlur
Postby bb3d » Sun Dec 15, 2013 10:28 pm
bb3d Sun Dec 15, 2013 10:28 pm
Wait... you implemented object motionblur, although Octane does not support it yet? :shock:
And are those cubes instances? Will 1.02 support instances finally?
Using Octane 1.11 on Intel Core i7 3770K @ 4,4 GHz / 16GB RAM / EVGA GTX670 SC+ 4GB driver 306.97 / Win7 x64 SP1
bb3d
Re: MotionBlur
Postby face » Mon Dec 16, 2013 8:51 am
face Mon Dec 16, 2013 8:51 am
bb3d wrote:Wait... you implemented object motionblur, although Octane does not support it yet? :shock:
It´s only a fake MB.
It combines the last and the current image together. This combined image will then used as the base for the next combine.
It isn´t so good as an average of a image sequence, but you haven´t to store all images in memory.
Which can be much heavy on a resolution of 8192px x 8192px and 32 sample images.
It´s also only WIP because i have some problems to make it working. For now it uses only 8bit.
The cube sequence uses the emTopolizer to make a single mesh.
For now i have to convert the plugin to work with the current SDK.
Also the new mapping modes must be implemented in the shaders and the code generation.
face
face
Mon Jun 17, 2024 6:52 pm [ UTC ]
