Yeap, I got the flip zy checked, at least when I do it manually or choose your export button, but if I hit render it goes unfliped.
Anything I could try?
btw I use max 2011
Also if I try to render a scene that in it's filepath has any space, octane 1.22 RC1 crashes
Beta 2.2 RC1: 3Ds Max plugin testing thread
- nirokugraphic
The tool seemed to work fine except a couple of minor issues:
1) The daylight setting wasn't obvious enough until I saw the video tutorial and realised that you had to set up a spotlight, tick the box and choose the light - I had simply enabled daylight and the script crashed when it tried to export . Neat feature when used correctly !
2) There seemed to be a little inconsistency between when rendering an animation that would sometimes generate an .obj and .mtl per frame (which would allow for object animation) and only one .obj (which would only animate the camera) - not sure if I was doing something wrong here though .
I also had the ability to export my scene from the tool and render it with octane, while there tweak the materials and lighting before going back to max to render the animation, at which point the animation would render and take the changes I made to the .ocs into account . I liked this but it didn't seem obvious to me at which point the .ocs file gets generated by the export tool, is it only when you click on 'export only obj/mtl' or does it do it on 'render' also, but not on 'render animation' ?
I was confused about the focal length parameter, it didn't seem to relate clearly to the octane ui, did I misunderstand it ? Aperture made sense .
Motionblur looks great !
scratch/post (Michael Todd) Independent Broadcast Designe + Visual Effects Artist www.scratchpostvfx.com
Max 09/2012 Win 7 64 | Quadro FX 3800 | Intel Core2Quad 2.39GHz | 8GB
The problem is that they don't do anything, well besides a beep soundkilaD wrote:What was the problem with the buttons?
Win 7 64bits / Intel i5 750 @ 2.67Ghz / Geforce GTX 470 / 8GB Ram / 3DS Max 2012 64bits
http://proupinworks.blogspot.com/
Which version of 3dsmax are you using?Proupin wrote:The problem is that they don't do anything, well besides a beep soundkilaD wrote:What was the problem with the buttons?
Give all information you can, we are not mind readers.
-mads
Amiga 1000 with 2mb memory card
... but are you posts readers? because that I mention in my first post[gk] wrote: Which version of 3dsmax are you using?
-mads
Hey, ill upload a new version shortly where you can control+click on the render/render animation to get the obj export UI.kubo wrote:Yeap, I got the flip zy checked, at least when I do it manually or choose your export button, but if I hit render it goes unfliped.
btw I use max 2011
Also i will fix the filename issue you are referring to.
- I`ll include the light fix in the next update! And yes, you need to setup a targeted light, omnilights work, but theyre not useful for visualizing the light direction.nirokugraphic wrote:The tool seemed to work fine except a couple of minor issues:
- For the animation part, the script is now only meant to work for object animation: Export obj & mtl, load in octane, render, save and exit, then it overwrites the obj & mtl and
keeps going like that until the animation end is reached.
If we only wanted camera animation, there wouldnt be any need to export the obj more than once anyway, just pass a list of camera positions to octane. I hope to see this
implemented in a future update.
- For now the ocs scenefile is generated only when pressing the render button
- The focal length parameter is basically the target distance. I agree, i dont see why you should want to override that parameter.
k
Hello
Thanks guys, you are making the octane experience much more smoother (if that's even possible hehehe)kilaD wrote:Hey, ill upload a new version shortly where you can control+click on the render/render animation to get the obj export UI.
Updated script (1.022c) available for download in the second post in the thread!
Hello
Proupin wrote: ... but are you posts readers? because that I mention in my first postmax2009 x86 on windows xp
I will try getting all functions to work in atleast max2008!
If you have some valuable input let me know
k
Hello
