Octane Render 1.022 beta2.2 RC1 available [obsolete]
radiance
mib2berlin wrote:Hi, "1. I'm getting these weird vertical lines that don't show up in beta 2.1:"
I get this error only with direct light.
2. I get black textures even with the chess scene.
Mib
1. switch to pathtracing and back to directlighting a few times and it should dissapear.
2. disable the 'use vertex normals if available' in the obj import prefs...
looks like we've got a lot of work to do on the weekend for RC2...
Radiance
Faizol
radiance wrote: works fine here... ?!
Thanks for the command line options.
Btw, (on Linux) I tried multiple variations; ./octane --help, ./octane -h, ./octane --Help, ./octane --HELP, ./octane -?, all went straight into UI.
Fedora 17 | 16 GB RAM | Quadro 4000 | driver = nvidia 304.xx & CUDA 4.0
radiance
it's noted, we'll check it for RC2.
Radiance
livuxman
For me, on linux, with -h, octane opens without splash screen and display a message about argument error with all the command line options although it takes 15 seconds to get the dialogue (something that always happens when you open the program)
LiVux 64bit | Geforce GTX260 Core 216 and GTX470 | i7 860 | 8Gb | Drivers 275.09.07 | Cuda 4.0.17
Whichway
radiance wrote:
Whichway wrote:So far, so good on big machine.
Benchmark scene, load and go: (DirectLighting Kernel)
1.021 - 1 GPU: 5.7 Ms/sec
1.022 - 1 GPU: 4.9 Ms/sec
1.022 - 2 GPU: 9.0 Ms/sec
Benchmark scene, load and go: (PathTracing Kernel)
1.021 - 1 GPU: 1.13 Ms/sec
1.022 - 1 GPU: 1.07 Ms/sec
1.022 - 2 GPU: 2.00 Ms/sec
Whichway
can you tell me which GPU types these are ?
Radiance
Should be in my signature, but 2x GTS 250
(There is also a GT 220 as nominal display adapter, but I actually access it remotely via VNC Viewer.)
Not so good on the laptop. Benchmark scene with directlighting kernel runs fine, but, from a fresh start, pathtracing kernel stops the driver as soon as rendering starts. There does not appear to be a driver update available for the CUDA Notebook Drivers.
Laptop: 8600M GT with 197.16 driver
Whichway
Win 7 64 Ultimate | GeForce 8600M GT | nVidia 197.16 | Core 2 Duo T9600 @ 2.50 GHz | 4 GB {being retired}
Win 7 64 Ultimate | 2xGeForce GTS 250 1GB ea. SLI | nVidia 196.21 | ASUS P6T | i7 920 | 6 GB
radiance
Whichway wrote: Laptop: 8600M GT with 197.16 driver
Whichway
does that driver support cuda 3.0 ? did 2.1 work on it ?
Radiance
mib2berlin
Mib
Radiance
2. This is working
1. I gave up after switching pathtracing and back to directlighting about 20 times :mrgreen:
Thanks rad, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
radiance
Mib
Radiance
2. This is working
Thanks rad, mib
very strange...
just use pathtracing then :) i'll fix this in RC2 coming monday.
Radiance
Whichway
Whichway
Radiance
Yes and yes.
Whichway
candide
Testing the vertex normals (from Moi and such) - it's much better now, the polygons are shaded, but there's some kind of weird "shadow" appearing under some angles when I move the camera (see pic). It happens with both daylight and environmental lighting. Test obj attached
Minor bug: the render display shows 60/0 MB memory used even though the device manager detects my total memory correctly
SingleCurvedPolygon.zip
(271 Bytes) Downloaded 189 times
Ich bin ein Octaner -- XP 32bit | Geforce 9800GT 1GB | Core2Duo 2.4GHz | 3GB RAM
