OctaneRender™ for Blender 1.20.2 - 2.4 beta Win [OBSOLETE]
JimStar
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • LiveDB material is now set to current active Blender material.
  • Simple workaround of nodes arrangement in node-editor after getting them from LiveDB. Nothing complex, as this is completely the Blender node-editor's responsibility to have the "Arrange nodes" function, so I will not spend too much worktime on some more complicated things here...
  • Fixed the bug affecting RGB colors of materials taken from LiveDB.
  • Minor improvements and bug fixes...
Blender Octane Edition - 1.20.2 - 2.4 beta (2.68a) (51.7MB autoinstaller file)
Octane Server - 1.20.2 - 2.4 beta (32.2MB autoinstaller file)
megacal
JimStar,
thanks for all the strong work! :)
2 GPUs: Zotac GTX 580 1.5gb Amp! GPU for Octane....Galaxy 210 1gb for display
CPU: AMD Phenom II X4 955,3.2 ghz RAM: 8gb OS: Win7 64
afecelis
Thanks JS for hearing us! ;)
Downloading and trying.
ps. Thanks a lot also for making the nodes from the DB show up nice and organized ;)
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
simdal
Thanks JimStar, everything works very well ... as Always!
thank you. hello, Simone
test live db 1.20.2 - 2.4 beta
Win 10 64, 4xGTX780ti 8xTeslaK80, Octane, Blender, Archicad
JimStar
Some additional details. The material nodes from LiveDB are serialized so far as tree, not as graph structure. So, in some materials you may get some redundand nodes doubled...
It's just temporary, I will improve it in next versions.
bluerocket
Thanks JS for the quick update :D
Asus Rampage IV Extreme | i7-3930K | 32GB | 2x GTX TITAN | 2x GTX670 4Gb | Win 64x
ephdot
Jim-
This is really low priority, but I found something. The following image shows the Live DB window within Blender.
Before delete...
Before delete...
If I right-click on one of the items that has an X and select Delete, the tree view goes a little crazy as per the following image. Again, very low priority, but I figured you might want to know about it.
After delete...
After delete...
-Dan
AMD-1100T 6 core, GTX-590 & GTX-480 1.5GB, 16GB 1600MHz RAM, 1TB WD 6GB/s, Win7 64bit, Blender 2.68a for Octane 2.2, Octane 1.20, Blender/Octane Server 2.2
JimStar
ephdot
I already wrote somewhere earlier: all the editing operations on the LiveDB materials tree are just stub for future "local database" feature.;)
Yes, when I coded the LiveDB, I've taken into account all the future things, so I've added the "in place" renaming, and context menu invocations... But it is not supposed to work at the time, I've just stubbed all these operations. As there is absolutely no sense to alter or remove some item, as after every tree refresh the state will return to the exact state of currently choosen LiveDB source (only OctaneRender LiveDB server at the time).
ephdot
Thanks Jim - my bad.
dafassi
I found out, that an actual material/node setup will be deleted when changing the material type iE from "diffuse" to "specular" or anything else.
That means, switching between different "surface-settings" is not possible without loosing the actual material setup.
How to reproduce:
Make a new matrial. IE a diffuse.
Add a texture node to the nodesetup and connect it to Diffusechanel from the diffuse Mat (or anywhere).
Now go to the Surface-windows and change Diffuse Mat in the dropdown to specular.
Now you see, that the texture node will be automaticly deleted.
Switching back to diffuse doesnt give me the textur back.
The good way would be to be able to switch between different surface settings.
By the way: Last try using animated textures did work - just the rendered preview windows doesnt actualize by it self whil changing the frame number ... did you do something or did i make a mistake o.O :D
WIN7 64bit • 32GB DDR5 RAM • Intel i7 6x4GHz • GeForce GTX780 • Blender
Return to “Blender”
