ok, FOUR quadtitan rigs! damn thats sick!
i will kepp on testing too!
aoktar, ok i will check that window more often. maybe i render a sequence af the problemscene again.
Testing Beta 0.87b (SDK 1.20) **updated 04.10**
- immortalartscom
- Contact:
My words....kirbyzz wrote:one thing i figured out today...had to work on a other normal c4d-job..no octane.
inside that project i get from my customer was a material with a normal c4d-level layer with a few simple layered materials.
I had to change that level-layer for adjustement but always i touched the layer-chanel cinema crashed...
Then i removed octane plugin from cinema-folder and it worked..don´t know why but i think octane don´t like the cinema 4d own level-layer.
I hope Aoktar now this does. If so, all the other falls are also probably finished, the octanes Render with C4D are caused, although he is not used at all, but only in the Plugin folder lies.
i think that's resolved now. I like to give a new test version to some people who has render problems. can anyone contact me?Rudi wrote:My words....kirbyzz wrote:one thing i figured out today...had to work on a other normal c4d-job..no octane.
- immortalartscom
- Contact:
contact you?
dod you mean reply here?
no, from PM. otherwise getting complicated. I need a few people to test render hangupsimmortalartscom wrote:contact you?dod you mean reply here?
- immortalartscom
- Contact:
two new bad things...
black frames or nothing with newest CUDA driver
and wrong rendersettings with rendering more scenes through rendermanager in R14.
i have a rendertime of 9 seconds per frame in picture viewer and 20-30 seconds in rendermanager in background. ahhh i need to render 23 animations. now i have to start every animation manually. i think rendering with rendermanager overwrites the rendersettungs from file? please have alook at that.
now its clear for me why the last time the rendertimes were so long!...
btw. i have to rerender the ENTIRE scene where i had doubleframes. what should i do? look at the console sometimes? make a bug report?
is it whql? what is the version?i send you pmimmortalartscom wrote:two new bad things...
black frames or nothing with newest CUDA driver![]()
now its clear for me why the last time the rendertimes were so long!...![]()
Hi all,
new version for testing only in first page with version code 0.86b.
- krzychuc4d
- Contact:
Hi Aoktar,
Is it only for R14+
or it also works with R13 ?
thanks
Is it only for R14+
thanks
http://www.3structures.com
https://www.facebook.com/3structures
Ryzen 7 2700X / 32GB RAM / RTX 4070 @Win10 64Bit
