Cinema vs Standalone Benchmark
sphericall
I know it should not be compared, but why there is such a big difference.
  • Oc Standalone computes 5.04Ms/sec
  • Oc via Cinema plugin (low_priority) computes 2,56Ms/sec
  • Oc via Cinema plugin (high_priority) computes 2,84Ms/sec
All parameters were reproduced in the identical or the most similar way. So than, why results are different, in the overall look and the speed in standalone is 2× faster than via Cinema?
Should I move back to standalone :?: :?: :?:
Here is the
OctaneBenchmark.zip
Benchmark for Cinema
(846.22 KiB) Downloaded 291 times
Try it on your systems and give your results.
Win 7 64 bit | 2 x GeForce GTX 660 | Intel Core i7-930 CPU 2,8 GHz | 8GB | Cinema 4d r15 Visualize (no Mograph, no Hair)| OCTANE benchmark scene 2,06 Ms/sec
i'm curious that speed difference is enough to leave this plugin ;)
i'm sure you doing something wrong!!! look my pictures
ok, i found. Scene scaling is different on scenes.
group all object and try to group with factor 100.0
Check your dimensions of objects. They are 4.5cm only. Try to change 4.5 meters.
Also set phong angles to zero
sphericall
Scaling ×100 helped :) now Cinema calculates 4,7Ms/sec
There was also New Model checked on in the Daylight Tag Sun setting, which changed the colour.
sphericall wrote:Scaling ×100 helped :) now Cinema calculates 4,7Ms/sec
well,
there is a bench scene in samples pack also.
Best,
Ahmet
sphericall
aoktar wrote:there is a bench scene in samples pack also.
Thx, I havent unpacked the samples pack yet! It's never too late ;)
