3DsMax Plugin 1.2, no fixed bugs
Leiurus
As mentionned in my previous post I just moved to 1.20 SA / 1.2 PI, doing a clean installation: uninstallation of previous SA version, deleting all 3Ds Max files, installation of 1.20 SA and copying 1.2 PI files in my Max folders.
For a reason, even though I can spot the difference with the previous version in term of speed (as announced), the Max interface is strictly the same as before: I still got the material preview bugs, the inverted bump mapping, etc...
Its quite confusing because we did a fresh installation on a workstation at the office (so with 1.20SA / 1.2 PI directly) and these bugs are fixed as announced.
How can I fix this?
Black Monster: Lian Li PC-X2000 | | Asus P9X79WS | I73930 | Quadro 4000 | 3xGTX580 | 64GB RAM | SSD OCZ 250GB | 4xHDD 1T RAID 10 | PSU Platimax 1000W | BR Burner | BR Reader
Monster Puppy: Dell M6600 | I72860QM | Quadro 4010 | SSD Intel 250GB | HDD 500GB
Karba
Leiurus wrote:As mentionned in my previous post I just moved to 1.20 SA / 1.2 PI, doing a clean installation: uninstallation of previous SA version, deleting all 3Ds Max files, installation of 1.20 SA and copying 1.2 PI files in my Max folders.
How can I fix this?
Are you sure you use plugin version 1.20? Could you show screenshot of your render settings tab?
Leiurus
Here we go:
Karba
Leiurus wrote:I still got the material preview bugs, the inverted bump mapping, etc...
Ok
Could you please explain it in details?
Leiurus
Well, basically it's exactly like if I was still under 1.17 plug-in version...
The material preview in the material editor slate do not update automatically. To update them I have to un-check the "auto" tick box and then update them manually. Quite annoying especially when it comes to color adjustment.
As I said, on the workstation we installed at the office (3Ds Max 2012 as well) this bug is fixed, the materials are automatically updated.
Karba
Leiurus wrote:Well, basically it's exactly like if I was still under 1.17 plug-in version...
That is strange. even in 1.17 preview should work properly. What gpu do you use?
Leiurus
3 GTX 580 for rendering and 1 Quadro 4000 for display
Karba
Leiurus wrote:3 GTX 580 for rendering and 1 Quadro 4000 for display
Could you open octane log window? Do you have any errors there?
Leiurus
I assume you're referring to the Octane log that you launch from the Kernel type slider?
If it is that one I opened it and it doesn't record any error...
EDIT:
The version I had previously installed was 1.13, not 1.17, sorry for the confusion.
Return to “Autodesk 3Ds Max”
