OctaneRender™ for Blender 1.20.2 - 1.3 beta Linux x64 [OBSO]
Forums: OctaneRender™ for Blender 1.20.2 - 1.3 beta Linux x64 [OBSO]
Postby JimStar » Wed Aug 28, 2013 4:13 am
JimStar Wed Aug 28, 2013 4:13 am
The TEST Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
Installation:
- Just copy the files from archive to root file system (into the same folder-tree as in archive).
- Run the OctaneServer as daemon:
# OctaneServer &
- Now you can start blender.
- If you got error messages that blender needs some libBlahBlah.so library - you can run the install_deps.sh script from installed blender folder with appropriate command-line keys. It will download, compile and install all needed libraries. If you dont want to install only the needed libraries - you can install all possible using --with-all key (but be ready it may take a lot of time to download, compile and install them all).
DOWNLOAD
Blender Octane Edition - v1.3 beta Linux (128MB archive file)
JimStar
Re: OctaneRender™ for Blender 1.20.2 - 1.3 beta Linux x64 [T
Postby Aenima » Wed Aug 28, 2013 7:38 am
Aenima Wed Aug 28, 2013 7:38 am
Great. Time to install a linux again
W10 x64 32GB, EVGA GTX960 - EVGA GTX1060 - OSX 10.12.5 - CORE I5 3.4GHz
Aenima
Postby kaiwas » Wed Aug 28, 2013 8:02 am
kaiwas Wed Aug 28, 2013 8:02 am
don`t work
kaiwas
OctaneRender™ for Blender 1.20.2 - 1.3 beta Linux x64 [TEST]
Postby JimStar » Wed Aug 28, 2013 8:17 am
JimStar Wed Aug 28, 2013 8:17 am
kaiwas wrote:don`t work
Do you have the "types.py" file in Octane addon folder? It seems that it is missing for some reason... Check it please.
JimStar
Postby JimStar » Wed Aug 28, 2013 8:22 am
JimStar Wed Aug 28, 2013 8:22 am
And are you sure that you run it from the right installation?.. As I see the folder name is "blender-2.68a-linux-glibc211-x86_64", perhaps you have mixed the two blender versions, plain 2.68a and Octane edition 2.68 somehow?..
JimStar
Postby kaiwas » Wed Aug 28, 2013 8:26 am
kaiwas Wed Aug 28, 2013 8:26 am
Yes. It is present. Files are aligned with the subject of the directory tree.
Thank you! The problem in this
UPD/ 2.68 does not solve the problem
UPD2 / Blender from the source archive is also not start. therefore combined the two "versions"
kaiwas
Postby Aenima » Wed Aug 28, 2013 4:14 pm
Aenima Wed Aug 28, 2013 4:14 pm
JimStar can you check the archive? I downloaded 4 times and i get error messages if i try expand.
Aenima
Postby JimStar » Wed Aug 28, 2013 7:57 pm
JimStar Wed Aug 28, 2013 7:57 pm
Aenima wrote:JimStar can you check the archive? I downloaded 4 times and i get error messages if i try expand.
I will check it when will reach the office. Yes, it seems like the archive became corrupted after uploading to server...
JimStar
Postby JimStar » Wed Aug 28, 2013 9:44 pm
JimStar Wed Aug 28, 2013 9:44 pm
Yep, the archive was broken.:shock:
I've just uploaded it again, then downloaded back, extracted and run both server and blender. All working OK now.
So, just download it again from the link in the first post.
Post here if you will still get some troubles with getting all working... Linux is full of troubles for end-users...;)
JimStar
Postby mib2berlin » Wed Aug 28, 2013 11:11 pm
mib2berlin Wed Aug 28, 2013 11:11 pm
JimStar, archive is ok now.
I have a few suggestions for linux users:
Expand archive to a directory of your choice.
Copy liboctane.so and octane.dat to /usr/lib64
Leave other files where they are and make shortcuts on desktop to blender and OctaneServer.
In KDE you can extend shortcuts to "Open in Terminal", I have it for OctaneServer.
If you close the terminal OctaneServer is also closed, you don´t have to kill the process.
You can make a directory "config" in usr/local/blender/2.68 than you have a separate configuration for Blender for Octane.
Other blender installations are not influenced from settings you make for Blender for Octane.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
mib2berlin
Next
Return to Blender
Users browsing this forum: Majestic-12 [Bot] and 2 guests
Mon Jun 17, 2024 1:26 am [ UTC ]
