OctaneRender™ for Blender 1.20.1 - 1.2 beta [OBSOLETE]
JimStar
OctaneRender™ for Blender plugin.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Changing some Octane values by arrow-buttons worked bad, fixed.
  • Fixed the issue with camera lens shift.
  • Fixed bug - Octane presets were not working.
  • Fixed "Color Correct" and "Gaussian Spectrum" textures bug.
  • Fixed "Fake shadows" bug in "Specular material".
  • Added "Aperture edge" and "Distortion" to camera settings.
  • Added "Spectral shift" and "Spectral intencity" to postprocessor settings.
  • Implemented current session statistics.
  • Blender is compiled with some additional modules enabled (e.g. Ocean simulator).
  • Minor bug fixes...
Blender Octane Edition - 1.20.1 - 1.2 beta (2.68) (45.0MB autoinstaller file)
Octane Server - 1.20.1 - 1.2 beta (18.3MB autoinstaller file)
myclay
Hi Jimstar,
first I wanted to thank you for the answers in the other thread. :)
I installed and tested the new 1.20.1 -1.2 version
when you have multiple Blender octane blends open and want to render simultaneously, it wont work anymore in this new build.
rendering with multiple blends would speed up the workflow, especially when linked Blends are used and you want to render and test yor materials while working on your main Blend.
the good thing about the old behaviour was also, that you could render 2 frames at the same time even on one graphicscard (only when you have enough ram)
will this feature of working and rendering and renderpreview with mutliple open blends be added back again?
Win 7 64 | Geforce GTX570 + GTX260 | i7 3770 | 16GB
JimStar
myclay wrote:when you have multiple Blender octane blends open and want to render simultaneously, it wont work anymore in this new build.
There was no such feature in previous version too. And nothing was changed in this regard in 1.2...
Just in case, checked it on 1.1 version - you can't render in second instance of Blender, if the render session is active in first one.
myclay
oh how dumb of me :/ XD
sorry sometimes I should sleep more.
I actually used octane and Cycles at the same time while rendering and forgot to change to the Octane Render.
MattRM
Good Job JimStar !!!
Matt
tungerz
Great work JimStar,
Should we uninstall Octane server 1.1? to keep everything in sync?
Or will it install over 1.1 and update to 1.2?
Thanks for your time and efforts in polishing the plugin :)
Cheers,
~Tung
Win7 64bit...Q6600 Quad core...8Gig Mem...9600 geforce...Daily Build Blender2.5x...Lionel's(Yoyoz)1.10 Blender Exporter... 0 Skill=Priceless
JimStar
tungerz wrote:Should we uninstall Octane server 1.1? to keep everything in sync?
No, just install over 1.1, both server and Blender.
Alain
Checkertexture looks wrong:
Here is the Blendfile:
Cube_Test_00_190813.zip
(77.61 KiB) Downloaded 358 times
Kind regards
Alain
Intel Pentium 2.8 GHz 2 Cores, 8 GB RAM, GeForce GTX Titan 8GB, Blender 2.72b, Win 7 64 Bit
steveps3
I think I've just found a bug. The direction of UVs appears to be 90 degrees to the way that Blender is showing them. i.e. I unwrap a plank of wood so that the grain is going along the plank but when I render it the grain is across the plank. Obviously this makes accurately unwrapping objects impossible.
Can anyone else confirm this?
(OS) Windows 7(64)
mib2berlin
Hi steveps3, no I cant.
Screen shot with unwrap from view for simple plane.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
Return to “Blender”
