I'm sure I'm missing something. In the lightwave plugin, if I want to apply a texture to an object that has no UV set up, I can connect a UVTool (can't remember what it's called) to the normal, and select various types of projection.
Is there a similar node in Standalone? Cannot for the life of me find it. If not, How can I project a texture onto an object without it having a UV?
Want to do some testing between versions.
UV Tool
- gordonrobb
- gordonrobb
Anyone?
I think that in standalone you always need an UV map to apply a texture image, there isn't an implicit texture projection node like the LW one, AFIK.
- gordonrobb
Well that's a bugger - or great for us LW'ers, depending on how you look at it.
- xxdanbrowne
@Gordon: I mostly use the standalone and I've never had to use a no-UV node on any of the nodes in order to add a texture: I just apply the texture and it goes.
Caveat: it's possible that zbrush, maya or marvellous designer (my three tools of choice) all auto-generate some kind of default UV when exporting the OBJ.
I haven't, however, explicitly created UVs in all cases and have just exported the OBJs with the intention of applying either a seamless texture or a procedural material in the standalone and it has just worked.
- gordonrobb
That's ok. I just wanted to try something in Standalone that I'm doing in the plugin, but it's using a texture image on an object with no UV (that's about 800K polys).
I wont bother, or maybe try it on a simpler object.
- xxdanbrowne
@Gordon:
If your texture is seamless it might still work. You don't lose anything by trying.
- gordonrobb
I had tried. That is why I was asking. It's ok, I' can create a UV on another mesh and try it. Got distracted by other stuff at the moment
