poser plugin animation rendering problem
when i try to render animation, there appear lines between body parts (chest, shoulder, forearm etc.) if no morph injection applied, there is no crease, but once morph injected there appear cracks. how can i fix this? please heip me !
- frame00003.png (275.69 KiB) Viewed 5054 times
Hi - What figure are you using? What figure skinning do you have set for that figure?
To help track down the issue - can you pls provide the info requested at http://render.otoy.com/forum/viewtopic.php?f=45&t=33672? Without knowing which version of Poser etc you are on - it's hard to assist.
This is in the "Figure" -> "Skinning Method" menu. What is it set at pls?What figure skinning do you have set for that figure?
pls = please.
Thank you for the info - that helps a lot. Although I am unsure what is causing the issue. There have been no other reports of this problem. Some ideas.....
1) If it just that figure or all figures? It may have a rigging issue - does the problem happen with other figures?
2) Can you see the seam in the Poser viewport?
3) Does it happen with other texturemap sets for that figure?
4) Try moving the Poser animation from frame 1 to 10 and back again - this will reset the vertex positions in Poser vertex buffer
Thank you for answer. but It's weird that problem happens only to me.
: all figure i use, v4, m4, ryan etc.
: during rendering poser viewport shows same, but after rendering poser viewport back to normal.
: yes
: I tried but the result is same.
: yes
Interesting. May I suggest reinstalling SR1 for Poser 2014. Also, try turning OFF OpenGl preview in the Poser render options. Let me know how that goes.
