Shadows in bumpmaps question
filipe_sheepwolf
Hi, I'm not sure this is a bug or something I'm doing wrong, but everytime I add a bumpmap to a material, the shadow on that object looks weird to me (too sharp)
I've attached a picture that shows what I'm talking about...
I'm even using a material directly downloaded from Ocane Live DB
So... Is it normal?
Thanks in advance ;)
Using 3dsMax 2012+Octane for 3dsmax 1.0
Karba
filipe_sheepwolf wrote:Hi, I'm not sure this is a bug or something I'm doing wrong, but everytime I add a bumpmap to a material, the shadow on that object looks weird to me (too sharp)
So... Is it normal?
That is not a bug. This is a limitation of bump.
nildoe
I too have this problem..Karba what would be the workaround to this?
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
JeffGalloway
I am also seeing this problem. Is there a work around yet? Would using a normal map instead of bump map solve the issue?
NemesisCGI
I found bluring the bump map helped at the loss of detail though.
It is I'm sure a bug, as I've never had this problem with any other render engine.
Win 7 pro 64bit GTX780
gordonrobb
I agree. NOT a limitation of bump maps in other programmes I use. A limitation of bump maps in Octane fir sure. Let's get some effort into fixing this.
tglaja
In the standalone Octane I always play with the rayepsilon value. That usually does the trick, at least for me.
GTX 560 2GB, AMD FX 8350, 8GB RAM, Win7 x64
Return to “Autodesk 3Ds Max”
