Hi all, running into another issue, I hit Viewport and the button seems to stay shaded out, no t viewport pops up, rebooted, re installed 1.2. Any ideas on this one, image below.
http://erotic3dx.com/misc/issue.png
View Port not displaying
The video card is working i can see that in the perf monitor i have and auto save is writing images to the save dir - the view port is just MIA? Tried rolling back to 1.17 same issue.
I ran updates on my Video card also everything seems to be working other than the Viewport not displaying?
GeForce GTX 670
This product has been detected as your primary device
Current Driver Version: 320.49
Latest Driver Version: 320.49
DOWNLOAD DRIVER
GeForce GTX 680
GeForce GTX 670
DOWNLOAD DRIVER
GeForce GTX 680
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
Seems like a poser pro 2012 issue, i installed 2014 and the issue went away ?
View port works fine.
I still have my 2012 install running if you need any logs etc...
This looks like the same problem JeffGalloway is having. Are you using 2 monitors? Can you pls send me In C:\Users\[username]\AppData\Roaming\Poser Pro\9\config.xml. You can then delete that file and you should be back up and running on PP2012.
1 monitor 2 video cards, one used for rendering 1 for OS, I will send you file.
Scripts -> Python Shell -> poser.PrefsLocation() [Enter] will give you the location of config.xml.i don't have Appdata dir
hey paul i sent you the file and then deleted the file, still same issue in poser 2012, octane works fine in my 2014 poser install
I just posted a new version which should resolve this issue.
