OctaneRender® for Poser (Windows) - build 1.20a [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Poser, build 1.20a (STABLE RELEASE). This version is compiled against Octane 1.20, so see the requirements for that build regarding compatibility with your video card.
This version runs on Poser9/PoserPro2012 and Poser10/PoserPro2014, on Windows XP, Vista, 7 and 8.
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Poser version (Poser -> Help -> About Poser) - list the build number (eg. 9.0.3.23027)
- OctaneRender for Plugin version (ie. X.XXa)
- Also have ready a copy of the octaneplugin.log and cuda.log file from your Poser temp direction (Poser -> Edit -> General Preferences -> Misc tab to find the temp directory)
- config.xml, which is in C:\Users\[username]\AppData\Roaming\Poser Pro\9 for Poser 9/2012 and C:\Users\[username]\AppData\Roaming\Poser Pro\10 for Poser10/2014.
Change Log from release 1.17a
- Plugin now uses "Linear Color Space" (see http://render.otoy.com/forum/viewtopic.php?f=21&t=33214). This means it converts the RGB color of an RGBspectrum node in the plugin node tree into linear space when the scene is loaded into Octane. This will mean that Octane will render the actual color you have selected in the color picker.
- The "emission" pin on a "scattering" node can now be disconnected if needed
- Added configuration option to enable/disable converting Poser Material specular maps to the Octane glossy material
- Added support for subdivided figures. Only available on Poser build 25276 onwards. Refresh times are much longer for subd'd figures, so remember to turn off Auto-refresh. Subdivided props are not yet supported.
- Fixed issue where number of meshes and vertices was not being reported correctly
- New Interpolated Vertex Normals type for Deep Channel Kernel
Potential changes for up-coming releases
- Add a checkbox to the Configuration to allow the user to Import/Paste retaining texturemap, but copy the gamma and power pins
- Add menu item to refresh the Octane material texturemaps from the Poser material
- Add Ability to continue rendering whilst opening a new Poser scene
- Add batch renderer
- Support for dynamic hair
- Support for subd props (figures are currently supported)
Known Issues
None
If you have questions....
- Read the latest up-to-date on-line manual
- Read the PDF manual (pdf manual is installed into C:\Program Files\Smith Micro\[poser version]\Documentation)
- Read the FAQ
- Watch the Features Video
- Read the Features Blog Posting
- Watch the Introductory Tutorial
- Watch the Instancing Video
- Check the Facebook Page
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download Links
Download the plugin from the following links:
- OctaneRender for Poser Windows 64bit
- OctaneRender for Poser Windows 32bit
ch0pper
thanks paul! will test in full this week end so far looks ok
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
Andygraph3D
I have see the panoramic render feature in octane 1.2. Can i use this features in poser plugin 1.20?
Yes - from memory you change the camera type in the rendertarget on the Settings tree. Fantastic way to creating your own IBL images.
Andygraph3D
Cool yes this is a great feature :D
thx Paul!
JeffGalloway
Found a bug.
When I try to change a rgb value and select OK or Cancel I get a modal window containing:
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 2525, in EventOk
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 2021, in EventNodeChanged
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 548, in SetOctaneApiNodeValue
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 2212, in displayError
ValueError: Error in SetOctaneApiNodeValue - null Octane node for node diffuse, node type = RGBspectrum
When I close the window and try to close the color picker it pops up again in an endless loop.
JeffGalloway
Upon further inspection, this issue may be related to abnormalities in the object geometry.
mlru
another weird object:
I get this error when trying to load that prop. I worked with it before and saved it with Octane materials exported back into Poser. trying to load it fresh ends with this messages:
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\__init__.py", line 73, in Render
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 3993, in ShowSetupForm
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 708, in FillTreeView
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 702, in FillTreeView
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 647, in SetTreeItemText
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 616, in ParamToString
File "D:\Programme\CGI\Poser\Poser Pro 2014\Runtime\Python\lib\encodings\utf_8.py", line 16, in decode
return codecs.utf_8_decode(input, errors, True)
UnicodeDecodeError: 'utf8' codec can't decode byte 0xfc in position 10: invalid start byte
thought, it might be because of a strange material name, but it doesn't seem so:
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
Hi Uwe
That error is actually coming from special characters in the image map of the Octane node setup for one of the materials. I will fix this in the next day or so.
Hi Jeff - would it be possible to email me that prop pls. You are right - it looks like there might be geometry that is not assigned a material or vise versa. Also, if you can load the prop, render it in the Octane plugin, then send me the resulting octaneplugin.log file, that would help.
Return to “Poser”
