It doesn't. What you do is create your own lights and attach an emitter to it.
What I do:
Typically I take one of my reality mesh light props and drop that into the scene. Usually 2 maybe 3 of these and i position them how I want around the subject. Any geometry works, but Sticking to simplier geometry or a flat plane is best. A flat plane will illuminate in one direction, where a sphere would go in many directions.
I then go to materials tab and change the material to a diffuse one for the prop we are using. It must be diffuse in order to attach a texture emmission node to the emmision channel. You can adjust the light color and power accordingly.
Not at the PC so no screenshot for ya. Hope this helps.
Genesis 2 female / Victoria 6 in Octane Render Plugin for DS
Moderator: BK
- larsmidnatt
Win10 x64
i9 10900k 64GB
2080S 8GB
DS 4.15 OcDS Prime ^_^
i9 10900k 64GB
2080S 8GB
- linvanchene
edited and removed by user
- larsmidnatt
Can anyone speak to this more? Thinking about this, this may be useful. But I don't know how it works or if it is something that is only available in the standalone.I had to render a HiRes image but was limited by my VRAM amount ( 1.2GB ). Thanks to the LensShift option, I was able to render tiles and composite them in Photoshop afterwards.
Thanks for sharing!linvanchene wrote:Just a quick update on the Genesis / Genesis 2 female surface name differences.
You can see a screenshot of the excel file below.
Win10 x64
i9 10900k 64GB
2080S 8GB
i9 10900k 64GB
2080S 8GB
Thank you, will try this.larsmidnatt wrote:It doesn't. What you do is create your own lights and attach an emitter to it.
What I do:
32 GB of RAM, Sabertooth x79,Intel Crest 180 GB SSD system drive, WD Caviar Black 1TB, i7 3930K CPU,
CoolerMaster Haf 912, CPU Cooler Master Evo fan, Windows 7 Pro SP2, Corsair AX1200 PSU, EVGA GTX 580 3GB Classified Ultra, EVGA GTX 580 3GB Classified
- larsmidnatt
- larsmidnatt
Thank you, larsmidnatt. This will certainly come in handy.larsmidnatt wrote:Did that help? here is a screen just in case
- larsmidnatt
- linvanchene
- larsmidnatt
looks familiar! still looks good
Win10 x64
i9 10900k 64GB
2080S 8GB
i9 10900k 64GB
2080S 8GB
