Can't see any DB Live material images
Moderator: BK
hm, from which version were you upgrading? can you please post a screenshot of the live db view?
„The obvious is that which is never seen until someone expresses it simply ‟
i meant the version you had before.pete1144 wrote:Version: v1_0_113_2313-x64
apart from that: can you please check if your cache folder is accessible? in the preferences tab, path settings, click the arrows button next to the cache path setting. this path should of course exist, in there should be folders named "LiveDbPreview" and "LiveDbTextures" - the *preview folder normally contains the thumbnail jpegs (means the plugin needs to be able to read and write to this folder)...
glad to hear that; i'm using SSDs too, that was one of the reasons to not overstress writing into places that can't be changed at least. btw, if you choose another directory from that dialog, the plugin will also move the contents...pete1144 wrote:Yepo , that was it. relinked and repaired. The problem was I recently changed the DazStudio Library to an external partition (I have SSD and file distribution is critical).u.All is working, again...thank y
