OctaneRender™ Standalone 1.18
roeland
Hi all,
This release contains a few extra fixes for 1.20. If we didn't introduce any new issues, this will be the version we will release as 1.20 beginning of next week.
Changes since 1.17
  • Inverted bump mapping behavior to make it more consistent with other renderers (lighter color means higher elevation). This means that when upgrading you need to check or uncheck the invert input on bump maps.
  • Fixed black dot on specular materials.
  • Loading of OBJ and MTL files which are not encoded as UTF-8, doesn't result in invalid node names and broken OCS files anymore.
  • Added separate display mode (Interpolated Vertex Normals) to the deep_channel_kernel to display the vertex normals before any correction to eliminate black rims on objects.
  • Fixed direction of horizontal scrolling on Windows.
  • Fixed some small issues with the minimum and maximum values for nodes.
Download:
Windows
ZIP archives:
- 64-bit
- 32-bit
MacOS X
DMG image:
- 32-bit and 64-bit
Linux
ZIP archive:
- 64-bit
Happy rendering,
Your OTOY NZ Team
smicha
Thanks TEAM.
Interpolated Vertex Normals works like a charm.
1. I reported it earlier - front and back views are switched - front is back, back is front.
Do you confirm it? (tested on models imported from Sketchup and 3Ds max).
2. When I set int2resolution (Mesh Preview Resolution) to higher values than the viewport is, eg. 3000x2000 I see no scrollbars on the bottom and on the right hand side of the viewport.
pixelrush
So soon... :roll: still we are making steady progress ;)
Ok well I reported the views icon needs a small triangle on it before to be consistant with the other drop downs. :)
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
gordonrobb
What? I haven't even installed 1.17 :)
Can you tell me if installing this, will also change the bump behaviour with the LW Plugin, or will that need to change too?
Elvissuperstar007
why you need a layer (Interpolated Vertex Normals)
I do not understand .. why so many normals. how to use them?
Last edited by Elvissuperstar007 on Fri Jun 14, 2013 10:59 am, edited 1 time in total.
win 7 /64x C2Quad 6600 2.4/ Nvidia 9800 GX2 1gb 512 bit + Asus 480 GTX/ DDR2 8Gb / NVIDIA 460 GTX 2GB/2x NVIDIA 580 GTX 3GB
juanjgon
gordonrobb wrote:What? I haven't even installed 1.17 :)
You need a new build of the plugin to see this change in bump behaviour.
face
Elvissuperstar007 wrote:why you need a layer (Interpolated Vertex Normals)
Only for error checking...
face
http://vimeo.com/user2509578
mantra
face
Useless...
MY WORKS
Cinema 4d | Win7x64 | 450gts
russian octane community
http://vk.com/octanerender
t_3
mantra wrote:Useless...
... for you?
mantra
... for you?
for 99.9% of customers
MY WORKS
