Animation Rendering?
Hey guys, So I'm trying to render out my first octane animation. I'm running the standalone version using the max2octane plugin to export from 3dsmax to octane. I've successfully setup a scene and it exports frame by frame, my dilemma is every time a frame renders, and it opens another frame to render, the camera aperture is back to the default and not at 0 as I've saved in the scene.. as well as its asking me for the .obj every time a frame renders.. which is time consuming to wait for the octane render view, manually take down the aperture and hit cancel on the obj part for 200 frames... is there a better way of doing this?
Win 7 Ultimate 64 /Intel Core i7 960 @ 3.20 Ghz/ 12GB DDR3 RAM/ Evga Geforce GTX 470 / 3Dsmax
Try to use make and use a batchfile (to render in DOScommand) and add the aperture in the commandlines.
I don't know how it works in 3dmax to make a batchfile.. Other users might help you better.
Greetz,
Greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
There is probably an export setting n the max plugin that lets you set the aperture. This may be overriding the settings in your scene.
I use the Blender exporter and I sometimes have the problem where if I save the file to a different name, but don't update the mesh node name (the imported .obj) to the same exact name, it wont load.
I guess it looks for an .obj named the same thing as the .ocs file.
Is this your problem?
Actually, even when I export with the obj, every time a new frame is rendering, it'll say missing obj file etc etc, i hit cancel, and it continues on loading just fine, so i basically have to wait for each frame, lower the aperture, hit cancel on the obj request, its such a hassle.. i wonder ,, does the 3dsmax plugin ( not the standalone + max2octane one) work well?
