CUDA Api error
maximum07
Good morning everyone. At the start of 4D cinema appeared this message.
Does anyone know how to fix it? I tried to update all the software but not
I solved it.
Massimo
Intel core i7 860 2,8 Ghz / 8 GB Ram / Nvidia GTX580 / Win 8 64bit / Cinema 4D R 14 + plugin 0.50.0 / Octane Exporter 0.12B / Octane standaolne 1.16
maximum07 wrote:Good morning everyone. At the start of 4D cinema appeared this message.
I solved it.
Massimo
it can be texture or ram limit error on gpu. it's consistent message or disapper?
maximum07
I do not think. The same project works on another PC with the same configuration. I don't know what to say.
Massimo
sphericall
Today after install last NVIDIA driver 320.18 I found that message while runing Cinema
and than
Be aware of new NV drivers. Now I'll try to downgrade them.
Win 7 64 bit | 2 x GeForce GTX 660 | Intel Core i7-930 CPU 2,8 GHz | 8GB | Cinema 4d r15 Visualize (no Mograph, no Hair)| OCTANE benchmark scene 2,06 Ms/sec
can you check gpu ram and texture usage when you recieved this message? I suppose reason is either one
