Add Fog raylight Alpha Background + clouds ( update 20.06)
visuall
final + post prod phtoshop
added fog for raylight effect
just added fog for raylight effet
I do not know if this is a good solution, but it's the only one I have found to overcome the lack of management background on octane without the need to render two images (hdri + sun)
tips by Enrico Cerica http://www.ronenbekerman.com/making-urb ... co-cerica/
OCTANE STANDALONE 4 | Octane For C4D | Win7/64 | 2XGEFORCE GTX1060| I7 3770 | 32GB
Seekerfinder
Good thinking there Visual!! The lack of HDRI + sun in Octane is a great limitation for me and many have been asking for it for a long time. So my guess is that the Otoy boys and girls have it HIGH UP on their AGENDA (ahem).
I'd love to know if you come up with a clever way to include clouds in the deal.
Your work is inspiring.
Seeker
visuall
Seekerfinder wrote:Good thinking there Visual!! The lack of HDRI + sun in Octane is a great limitation for me and many have been asking for it for a long time. So my guess is that the Otoy boys and girls have it HIGH UP on their AGENDA (ahem).
Seeker
thank you seeker,
uses the same technique, a plan with an alpha texture cloud;)
sdwhitton
Hi there
not sure what you're doing here - is it an hdri mapped on to some geometry with an emitter added?
workstation well past its sell-by-date, Vista 64 bit (!) with a pitiful amount of RAM, re-invigorated with a GX 590
3ds Max Design 2011 (have 2013 but can't be bothered to re-do all the UI), CS5, and that free z-brush program, whatever it's called
visuall
sdwhitton wrote:Hi there
No, si a plane with alpha matérial for cloud and background , sun/sky emiter only
mbetke
I go with a fully 3D approach on this kind of scenes.
So some bushes and trees in the background and a simple image in post to replace the alpha.
Most of my scenes are made this way. It is fast, renders are not throttled down because of alphamap rendering and I can replace quickly if needed.
If I have an open scene where I need reflections I scatter more 3D and maybe some building around the scene and get a nice bounce of light.
But what i definitly would like is to use a HDRI as a reflection slot. Like Maxwell Render uses it.
PURE3D Visualisierungen
Seekerfinder
Seeker
thank you seeker,
Great! Thanks Visuall. I'll play with that a bit.
Seeker
Seekerfinder
mbetke wrote:I go with a fully 3D approach on this kind of scenes.
Mbetke,
I don't get it. You're not bringing an alpha image INTO Octane - I get that. But don't get how you place a 'simple image in post to replace the alpha'. Perhaps I'm missing something regarding Octane's output ability but, depending on the image complexity of course, inserting a background image in post can be extremely tedious (unless you have the simplest of large openings in a space). And so I think Enrico's approach to render twice (one with HDRI and one with sun) and simply merge in post is a much simpler and less time consuming approach. And Visuall's approach seems a good alternative to avoid that. What are you doing that is different to a normal post process?
Seeker
mbetke
In your shot your trees are 2D planes with an alpha. Also The cloud.
I use real geometry there and no clouds.
All I meant is I render my image with "alphachannel" and put an image behind the scene. Sometimes some 2D trees too.
In your case I would just place the ground with the slide (maybe a line of bushes) and all behind it would be black on my output.
Like this image:
http://pure3d.de/layouts/p3d/gallery/Pu ... _3D_05.jpg
Behind the tree and white fences is just a landscape image.
Its the most easiest way to have a small scene which renders quickly and pasting a background image doesnt even take a minute.
If you put your background into the rendering you have to setup your 2D trees, the cloud image or even re-render if client wants suddenl pine trees and no apple trees (just as an example).
Seekerfinder
Ah,
So you just render with black background to make it easier to replace in post. Thanks for sharing Mbetke.
PS: that's not my image - at this point I can only aspire to the standard of work that Mr Visuall produces. But I'll get there eventually.
Seeker
Return to “Works In Progress”
