the PSU is enough for the whole system : it's a 1600W. for the [email protected] and 3 titans, only need 1100W full load (CPU + GPU).
Else, you can add another PSU in parallel. I did it when I only have a 900W.
OCTANE BENCHMARK: Submit performance scores for your rig!
- mauricesteenbergen
Hi,itou31 wrote:@smicha
Soory I have not mentioned that the PC is NOT in my room, it's is remotly controled and it is in the garage where the temperature is about 18°C
What remote option are you using? Very interested in this.
How about building a PC in a freezer
Render: Geforce GTX480 (EVGA) (1.5GB) | OC @ 1.0V / 750Mhz
Display: Geforce 8800GT (NVIDIA) (512MB)
OS: Win 7 x64 | CPU: Quad Intel Xeon 2.66GHz (12GB)
I use RADMIN remote desktop with octane standalone or 3dsmax plugin. The client is just a small NUC with a big screen.mauricesteenbergen wrote:Hi,itou31 wrote:@smicha
I have also use windows remote desktop for DAZ plugin because of pb with opengl.
In a freezer ? not a good idea !(humidity !!)
I7-3930K 64Go RAM Win8.1pro , main 3 titans + 780Ti
Xeon 2696V3 64Go RAM Win8.1/win10/win7, 2x 1080Ti + 3x 980Ti + 2x Titan Black
There is also free (for non-commercials)itou31 wrote: I use RADMIN remote desktop...
http://www.teamviewer.com/en/download/windows.aspx
yes I know and tested it, but RADMIN is a lot faster when use it on LAN. The only problem with most of remote desktop software, is that DAZ (ie octane for daz) cannot be used fully. When I work with DAZ, I should use windows remote desktop v6 and not the metro windows 8 version.
I simply made a 3 inch hole in my wall with a blend. Took extra long cable and installed the computer into another room! 8 X USB 3.0 hub for mouse, 3d mouse and other USB devices - done!
Works great since 3 Years now. And i have the "most silent" pc you can get!
Kind regards Chris!
Kind regards Chris!
780 seems to be close to titan (in terms of performance)
http://youtu.be/3gB9-eIPLzM
If 790 comes out 4x790 will be the beast (3gb of vram though)
Titan is about +15% performance over 780 for octane.
but the price is +50%
So I think that 780 is the best choice if 3Gb is enough.
http://www.tomshardware.com/reviews/gef ... 16-26.html
First test with GTX 780
score 4.93
https://dl.dropboxusercontent.com/u/277 ... octane.jpg
No overclocking done. I understand that It's possible to OC this card a bit without making it too loud or hot. As you can see the fanspeed didn't get very high.
score 4.93
Win 7 64 | Geforce GTX780 | i7 3930k| 32GB
you should play with the 1.16, it's faster !
and yes, the 780 is fast and "cheap". you should try some overclocking....
