Testing Beta 0.49/0.50 ( Old version)
indexofrefraction wrote:
aoktar wrote:I'm curouis that are you aware about shader to texture option of my plugin?
uhmm.... now i feel a bit.... going to report back on you ;)
ok, it's working some shaders and can have problem with layers. But it's a testimonial feature at this moment. At least a tryout for helping to you.
Uv mapped shaders must be working correctly but need precomputation before rendering. Some others not works because shader input parameters as Fresnel, etc...
mantra wrote:plz position pass
ok, i'm goint to check
mantra
Thx
MY WORKS
Cinema 4d | Win7x64 | 450gts
russian octane community
http://vk.com/octanerender
AndreaMannori
Great news! Thank you..but.. It crashes C4D as soon as it start!
Andrea Mannori
win 8.1 x64; nvidia 770M driver 340.52; octane standalone 2 + c4doctane 2.
renderfarmsrl wrote:Great news! Thank you..but.. It crashes C4D as soon as it start!
if it crashes while starting install is not clear. some old data causes crashes.
Check older threads, we have discussed this
AndreaMannori
Now it crashes when starting the final render (it's all right with the live render).
It's a problem related to the Render Instance check ... it doesn't crash if Render Instance is not enabled.
See the attached log.
_BugReport.zip
log
(16.33 KiB) Downloaded 249 times
Andrea Mannori
renderfarmsrl wrote:Now it crashes when starting the final render (it's all right with the live render).
Can you send me scene?
huebner
please help
maype there is a professional Cinema user!
how can i get a Cinema model devided by materials? i just want a simple polygonobject for each material.
means to undo all the polygonselection-tags for the whole model!?
group afterwards by materials.
is there a plugin/export-way to reach this with one step?
otherwise i don`t see a "economic" way to texture my models from revit.
thx
octaneritter equipped with 2 x gtx 680
AndreaMannori
@huebner - you have at least 2 ways to do it: 1) export obj from revit -> export options -> export by material group; 2) manually modify your scene by opening the material -> assignement -> select all objects -> go to the object tree -> right click -> merge and delete. Repeat it for all your material and you'll get as many objects as your materials number.
@aoktar - yes ... the scene attached works fine because the Render Instance check is set to off. Try to set it ON and then render to reproduce the crash. Thank you in advance. (if Render Instance is not checked... does Octane save vram anyway?)
Glasses_test.zip
(3.16 MiB) Downloaded 258 times
Andrea Mannori
hi andrea, no problem here with your scene, try disabling the "render perfect" option in the bubbles spheres and remember to invert the lathe nurbs and activate the "fake shadow" option in the specular materials ;)
with liquids in glass it's necessary to slightly overlap the two geometries for a correct refraction effect ;)
ciao beppe
