Question: SSS Skin & Alphashadows & hair
JeffGalloway
I have seen on this board that you need Alphashadows disabled to get a good SSS effect for skin. (I've tested it for myself and it is true, alphashadows enable kills the SSS effect)
But disabling Alphashadows created a big problem for transmapped hair, eyeleshed, etc.
How do you get around this issue?
ch0pper
Alphashadows disabled ]
I have never disabled these whilst rendering, but I will have a play and see what I can comeup with, never really had a problem as all my renders seem to have this enabled. Maybe you could post some of your findings be interested to see what your pictures look like
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
There was an SSS fix put through in Octane 1.13 too - so this might be different on that version. If not - then it is a general Octane issue and should be reported to Otoy.
JeffGalloway
Example Issue. This is done (with the poser plugin) in v1.13
KleanZlate
JeffGalloway wrote:Example Issue. This is done (with the poser plugin) in v1.13
Have you tried setting Absorption and Scattering to 0 and Phase=Scattering Direction to 1?
Windows 8 64bit, Intel Xeon 3.4 GHz x2, 10GB RAM, GTX 660 Ti 2GB, Poser Pro 2012 SR 3.1
JeffGalloway
KleanZlate wrote:Have you tried setting Absorption and Scattering to 0 and Phase=Scattering Direction to 1?
Yes, I have tried that - and it does not give the same effect that I am getting with alphashadows disabled. There is something about the alphashadows enabled that deadens the SSS effect especially in the large volumes of the body.
Thanks for the comparison image - very useful. I have escalated this issue to Otoy.
Otoy have looked at this, and been able to reproduce the problem in Octane Standalone, so it will be fixed in a future release.
JeffGalloway
That's good news!
JeffGalloway
Can you tell from this:
http://render.otoy.com/forum/viewtopic.php?f=33&t=32582
...if the fix for the above issue made it into this (1.15) release?
Return to “Poser”
