Beta 0.3.4 released (Old version)
pxlntwrk
ok thanks ;)
pxlntwrk.net
AndreaMannori
Thank you for the answer Beppe, do you mean that the texture issue is only related to the C4D integrated plugin (planar mapping)? So, if I use the Octane standalone I don't have any issue ... probably because I must assign unwrapped uvw anyway, isn't so? :) thx
p.s.: I hope otoy will speed-up the exporting and voxeling processes for heavy poly scenes ... sometimes the render time is slower than exporting!
Andrea Mannori
win 8.1 x64; nvidia 770M driver 340.52; octane standalone 2 + c4doctane 2.
renderfarmsrl wrote:Thank you for the answer Beppe, do you mean that the texture issue is only related to the C4D integrated plugin (planar mapping)? So, if I use the Octane standalone I don't have any issue ... probably because I must assign unwrapped uvw anyway, isn't so? :) thx
no sorry, exactly the opposite, if octane doesn't have an option also the plugin doesn't have that option ;)
about the exporting time, in my opinion the plugin and the last octane sdk have speed up a lot the things, now we have the ability to update only the materials or the geometry per frame and multi core support during voxelization process ;)
ciao beppe
César wrote:Hey Aoktar,
I can't add an emissive texture to a material, I try to add a FloatTexture to the Texture field of the Emission channel, but it do nothing, it don't add it.
Is there something I do wrong ?
probably, if the emission channel is active we should only choose between blackbody-emission or texture-emission node :roll:
ciao beppe
pxlntwrk
Re,Hi
Correct me if im wrong, but the gamma cursor seems to be inverted like ?
gamma 0.45 should it not be more dark and crispy than 2.2?
gamma 0.45
gamma 2.2
thanks
pxlntwrk.net
it's exactly how it works on standalone since the very beginning, but i don't know why :D
anyway, in octane you must set the hdr gamma to 1 in order to have the correct illumination, gamma >1 are useful for getting more contrast and less blurry shadow ;)
ciao beppe
pxlntwrk
ok thanks for speed answer!! :D
I will invert my brain too
pxlntwrk.net
areafilm
Hi, I have a big trouble.. in my I7 system with Geforce 670 with Cuda 5 drivers.. no I've not material preview in the material editor..
If I create a new Octane material I get a empty grey.. the same if I make a material conversion in Octane Material.. empty grey..
The render still correct.. Somebody has experimented the same problem?
I have tried to reinstall Cuda 5 driver and Geforce new driver..but is the same..
I don't know if the problem is the Cuda drivers.. Octane C4D plugin work with Cuda 5?
Please help me.. Thanks
uncia
Hi all. I'm testing pluging and i can't get panoramic camera to work. Cinema just crashing.
areafilm wrote:Hi, I have a big trouble.. in my I7 system with Geforce 670 with Cuda 5 drivers.. no I've not material preview in the material editor..
Also when the send scene to render? 0.3 versions need firstly start a render.
