Beta 0.3.4 released (Old version)
- cglittenberg
- Contact:
I have now started using Octane C4d in production rendering and medical simulation. One question: It seams to update the meshes and materials inbetween every frame whether the boxes in the render options are checked or not. Checking them seams to make no difference. Is this a problem for anybody else?
Dr. Carl Glittenberg
Glittenberg Medical Visualizations
Intel(R) Core(TM)i7 CPU 860 @ 2.80Ghz 2.80Ghz 6,00 GB RAM Windows 7 Home Premium Nvidia GeForce GTX 480
Nice to see:)cglittenberg wrote:I have now started using Octane C4d in production rendering and medical simulation. One question: It seams to update the meshes and materials inbetween every frame whether the boxes in the render options are checked or not. Checking them seams to make no difference. Is this a problem for anybody else?
Materials will be updated correctly on any changes, also lights, camera, environments.
Also plugin support geometry updates, but actually only can keep polygon object synchronisation. Generated/modified objects can lost own id's. Next updates will be corrected.
i'm updating manual
http://render.otoy.com/manuals/Cinema4D/?page_id=359
- Silverwing
- Contact:
Hi aoktar:
Found a small Bug:
Description:
When I start a final render in the Picture Viewer and abort the rendering during export or voxilisation of the scene (before I see the picture building up in the viewer) C4D crashes!
As soon as I see the picture in the Picture Viewer I can cancel the rendering normally.
Just wanted to let you know
Cheers,
Silverwing
Found a small Bug:
Description:
Cheers,
Silverwing
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
Silverwing, many thanks. Exporting has a bug as you say. Because not check break for closing. I have noted.Silverwing wrote:Hi aoktar:
Found a small Bug:
Description:
Cheers,
Silverwing
- AndreaMannori
Cool!
Hairs: 600'000, 12 pts.
Trees: 100 clones, 41'300 polys each.
PT, 16, 2048 samples in 1 hour on a GTX 590 - 3Gb total vram.
I have to say that live view doesn't render hair... I can render hair only by hitting the render button. Is this a bug?
Andrea Mannori
win 8.1 x64; nvidia 770M driver 340.52; octane standalone 2 + c4doctane 2.
nice try:) hair is done with instance? I'm not sure about live view. But normally can render instances, there is no different between Render View.renderfarmsrl wrote:Cool!
Need to check
- AndreaMannori
Hair direct render
Next I will try the Render Batch list...
Andrea Mannori
I noticed a little memory problem, the RAM don't seems to decrease when we close the plugin or the document after a render.
After some hours at working on a project with the plugin opened, the used RAM gradually increase to the limit and finally block C4D. The project is not particulary heavy (115 Mb of VRAM).
I'm doing many tests for similar problems. I hope next release will be more solid.César wrote:I noticed a little memory problem, the RAM don't seems to decrease when we close the plugin or the document after a render.
Aoktar, when will be next release? (This week, next week or this month?)
Sorry for my English
Win 10 x64 / amd fx-9590 5.0Ghz / 3xGTX Titan Black 6gb/ 32gb / ArchiСad 19 / Cinema4D R17 / latest Octane.
